my ABS pump was not sending fluid to one whee,l I verified the pump the aluminum casing had one of the holes clogged or something I was not getting a drop of fluid out of one hole. I went ahead and ordered a used part from Ebay now my question is. Should I remove the manifold from the old pump and put in the new manifold and use the original electronics from the car or can I just put in the whole new pump? If I just put in the new (to Me) complete pump do I have to reprogram it or something? I know I have to bleed it but do I have to do anything else? I saw one guy on YouTube say that he is using the original computer so he does not need to program anything, is this true?
