On my ‘06 987, the fog lights switch will not turn on the fog lights, nor do the little lights by the switch
I tested the Fuses 5 and 7 on the top row, they are good.
Edited by jim_hoyland
add info
Solution found !
Went over to SMS in Huntington Beach. Branden took a light switch out of another Boxster and tested it in my car. Sure enough, it was the switch.
Also learned how easy the light switch comes out.
Ive ordered a replacement from Pelican. Free shipping….
Link to https://www.pelicanparts.com/techarticles/Boxster_Tech/87-ELEC-Headlamp_Switch/87-ELEC-Headlamp_Switch.htmIMG_0625.jpeg
Update
  • jim_hoyland changed the title to Dead fog lights; solution found !
IMG_0629.thumb.jpeg.e93a8340bf79e3a41c8f9bcbca8c058a.jpegBut wait ! The new switch arrived Friday ( Part# 997-613-535-01-A05-OEM ), but when I swapped it in, the fog lights still didn't work ??? Previously, we swapped in a known switch from another Boxster and the fog lights worked fine; this replacement switch won't turn on the fog lights.
The switch has a ten (10) pin connector; is there a way to test the functionality ??
Typo
  • jim_hoyland changed the title to Dead fog light switch..,.
