Hey Loren do you know what pins give what? My cd changer died and appears to be completely dead. I took it apart to remove the cartridge. I have done this once before and there was something just stuck inside the changer- improper operation. In any event do you know if the changer gets a constant volatage? I want to check the cable and rule out the source. Thanks. Sean
Also I did the headlight amber removal from my litronics. However when I put my drivers side back in, the turn signal isn't working. It appeared that the bulb looked ok however. I have taken it out and back a couple of times to no avail, ideas? Thanks Sean
CDC-3?
Did you check the cables in the front trunk? They can come loose if pulled on. Three of them as I recall.
Try a know working bulb. Sometimes bulbs look good - but aren't.
Swap the left and right bulbs. For instance, sometimes a break in the filament is not (easily) visible to the naked eye. If the problem follows the bulb, then you know (what Loren said); if not, carefully check the socket for a detached wire, bent contact, etc.
--Brian
Edited by Q-Ship986
The changer only has 2 connectors the one round one with the power and control and then the rca out one.
I will swap out the bulb and see if it's just that. Hopefully it is :)
--Brian
Hey guys I picked up a set of new bulbs 6.50 at "the zone". It was in fact a dead bulb. It was interesting because by sight you could not tell that the filament was disconected Thanks!
