URGENT - 18" Cargraphic Rims on '01 TT
:help: I'm currently looking to buy a set of rims to put racing tires on my 996 '01 Turbo. I could strike a deal to buy 4 Cargraphic Gemballa rims in the sizes:
Front: 9.5 * 18 ET 62
Rear: 12 * 18 ET 28
My regular Posche AG 18" measure as follows:
Front: 8 * 18 ET 50
Rear: 11 * 18 ET 45
Can I fit the Cargraphic's on my Turbo without any problem. I do NOT want to have to fit spacers or other adapters.
Thanks for any advise :lightbulb:
Rear: 12 * 18 ET 28
Front: 8 * 18 ET 50
Rear: 11 * 18 ET 45
Do you have particular rubber in mind that you would use?........I always tell people it's pretty bass-ackward to buy wheels, then look to see if there's rubber to fit em (not just any rubber, but the rubber you want, cause that's for more import than the rim).
Those 12Js with 28mm offset are going to be out there........if you have signif lowered suspension you may be looking at fender prep.
Boy I don't know about 9.5Js up front......what rubber are you going to use up there?........keep in mind your front-rear size differential.
BTW.......OE hollows at only about 20 lbs make for respectable track wheels....paint em any color you like.
