I am planning to install OEM 18" wheels on my 01 996C2, where previously I had only used OEM 17"...
According to the TSB #4440 (8/10/04) the it says "The wing seam and if necessary the rear spoiler must be reworked on vehicles up to and mincluding MY 2001 if running 285/30 tires." Does anyone know what this means?? Can I just install the wheels/tires?
Thanks! Ross
I did not have have any problems with the 285s and 10" factory wheels (63 mm offset).
If you use larger sizes like 295 and 11" wheels then I think you may need to taper that seam back.
I also have a 2001 996 Coupe. What are the handling advantages/disadvantages of installing 225/40/18 fronts vs 235/35/18 and 265/35/18 vs 285/30/18 rears ?
FWIW It seems some tires, like Michelin Pilot Sport PS2s, only come in 265/35... not 285/30.
