Hopefully I've set up the title and description correctly. I'm new at this.
Is there a way to check out a part number to be sure it's a compatible part? The P/N is 996 803 089 02 A28. It is an airbag with a black leather cover. I'd like to be sure that I can install this on my '03 Targa before I go to the trouble of taking it apart.
Advice is welcome.
Dwayne
Loren,
Thanks for the quick reply. Looks like it should work according to the part info you have. Now comes the attempt to avoid setting off the airbag light during the changeover.
Dwayne
