All Activity
This stream auto-updates
  1. Past hour
  2. Today
  3. Is the metal ferrous (can be picked up by a magnet)? A photo would be helpful.....
  4. Yesterday
  5. Try 0869
  6. Hello. Looking for a radio code for my 986 Serial nr 15076700 BE4462 CDR 220 Thanks!
  7. Hi All, I am retro fitting an aftermarket camera into the factory automated pop out on my 2009 Cayenne Turbo S. I have an aftermarket head unit which is the pioneer DMH-WT8600nex. I have successfully integrated it into the Porsche system including the fiber optic and I now have remotely run wires for the new retrofitted pioneer BC-10 camera into the mechanical body. I reconnected the PCM temporarily to re-enable the backup camera pop out and then pulled fuse 55 to reset the system because I couldn't find the setting... I can confirm that it reset and when shifting to reverse the mechanical body did operate but when I reconnected the pioneer head unit everything worked except the mechanical body coming out. I'm hoping that somebody is familiar with the pinouts on the PCM or has a diagram so that I can figure out which pin runs the trigger for the mechanical pop out. TIA! p.s. I have done a preliminary run with a multimeter verifying each lead that I could reach that didn't have power when not in reverse but none had power when shifted into reverse... the only step I can go from here is to get my needle leads out. Update: I ended up using my needle leads and tested all the wires to the factory harness. I can say that the lead is in the blue block that connects to the micro pins, I can also say that it is not a standard voltage signal. Most likely it is a canbus signal that activates something remotely like a relay. Today I will probably pull the voltage of the factory motor lead and just run a new circuit for it. Hope this can help someone in the future.
  8. I do not know the cause but there is metal in the oil. I had the IMS bearing replaced 4 years ago but sadly the warrantee has expired. I had a 60k mile check up at a Porsche dealer less than 2K miles ago but they missed it and claim to have no obligation. Sad... Option 1: Replace the engine. $25k to $30 is my best guess Option 2: Sell it as is Thoughts? Advice?
  9. Anyone can help me to find valves of the coil. So i can order new one. Im at the point where is no turning back 🙂
  10. Last week
  11. That worked! Thanks so much!!
  12. Try 6707
  13. Hi Loren, Would you please provide the code for this Becker CDR 210 SN: V5011320 First character could be a "U". Many thanks!!
  14. Perfect! This works. Thanks again and have a great weekend!
  15. Try 8386
  16. W5011176 I need the radio four dugit code
  17. Porsche use to have a sticker on the inside of the hood which, if I remember correctly had the vin and other identification number for the car & options. Does Porsche put that on anymore - the sticker? My ‘06 had it but not the new 992.2 I just picked up. Tks!
  18. Try 1634
  19. Earlier
  20. Just got a Becker CR-210 (BE2182) with S/N V5008528. Can you help with code? Thanks.
  21. Thanks so much!
  22. Try 9830
  23. Becker CR-1 SN: POCR-1MO812515
  24. Try 9290
  25. hmmm!?! Thanks Always, It depends...
  26. Without actually seeing the car, it would be pure speculation of what is needed, and caliper studs or bolts, it still has to come apart, but sometimes using studs actually slows down the process because they are simply in the way when the caliper has to come off............
  27. Oh, BTW Has Brake Studs installed: Does this reduce labor time? Thanks, JJ
  28. Thanks. Your good thoughts are echoed and embedded in the local shop's idea - to replace all - rotors, sensors and pads. Interesting that they would like to do both front and rear -- when only the front seem to exhibit low-speed squeal. Now the question is: How long can we live with the functioning system? Appreciate your input, JJ
  29. New to me 911 with a CR-220 type 4362 Serial no Y5024557 An unlock code would be greatly appreciated!
  30. Most noise issues are related to how the pads were installed; did they use the correct lubricants and install noise dampeners if so equipped? If the current pads have not been done correctly, just replacing them will typically get you to the exact same place.............
  1. Load more activity
