Muffler bypass Pipes
This is the install for muffler bypass pipes, from Ebay $200. All you need after getting the pipes is $2 pipe joints from an autopart store. The mufflers I have are DHL, and I have removed the mufflers before and re-installed them. If you have, hopefully you have installed the bolts that hold the mufflers to the brackets upside down. This allows for much easier removal and install of the bypass pipes. If you haven't, don't worry, now is a good time. 1. Get rear of the car up for easier ac
Edited by Izzy
  • 4 months later...
Can anyone tell me about the oxygen sensor when driving car without the cats on as in running straight pipes for the track if i'm not mistaken the sensors are in those pipes and if you can help me about sensor install if i make my own straight pipes i.e. is the distance from the exhaust valve relevant as in tuning pipes for rpm ? Thx tut
  • 8 months later...
  • 6 months later...
