37,340 -
Days Won
536
Posts posted by Loren
Yes, from under the car. You will need to remove the rear most belly pan and the switch is up high on the transmission.
996 606 103 01 Switch - retails for about $6
I will need the model year and exact model (C2, C4, C4S) and transmission (6 speed or Tip).Do you have a part number for this piece so I can get it from the dealer? Is this something that I can get to without having to remove any other parts underneath the car?Thanks.
Sometimes a good parts department will know the different pins and connectors - because they have replaced one in their shop. So they have already done the trial and error ordering.
Only Contributing Members here can view TSBs here. As well, they get access to a Contributors Only Forum, they can send attachments with PMs, image storage limits are raised for all Contributing Members, RennTech.org email addresses are available and now a personal Blog.
Contributions help defer the cost of running this site and providing this information to you. No one has to contribute but many members do. Without contributions this site would either have to go subscription or cease to exist.
Boxster Turbo Look I
7.5 J x 18 H2 offset 50.0 mm 993 362 134 06
9 J x 18 H2 offset 52.0 mm 993 362 138 01
955 559 038 01 4w9 Cayenne Turbo Logo in satin aluminum
The things that I think would matter would be:
The air inlet ducts - C4S or standard later model.
The bumper reinforcement on C4S and TT is shorter than the older Carrera version. So it might have to be cut or changed for the shorter one.
We have added the DME 7.8 P-Code listing to the OBD II P-Codes section. This covers:
DME 7.8 - Boxster (986), S MY03-04; Carrera (996), 4, 4S MY02-MY04; Turbo (996) MY01-05
Isn't that what a 40 year anniversary 911 has?
Okay I have a DME 7.8 listing now. :D
Give me a few days to get it online here.
P0172 - Oxygen Sensing Adaptation, Idle Range, Bank 1 – Below Limit.
P0175 - Oxygen Sensing Adaptation, Idle Range, Bank 2 – Below Limit.
You lost me there... there is only one x73 kit for a C4S on Carnewal.com.
There is a kit for C4 "turbo look" - which will I believe is the RoW standard sport suspension for a C4S (this is lower than the US standard sport suspension). If you are not sure email Gert - he is very good at getting you the right parts.
If your car is a non-MOST car then it has conventional wires instead of a fiber optics network. I don't know why that would be a problem.
I think you will find the parts of the wiring harness listed below the 996 612 903 00 number. You may have to buy the pins separately from the connector and assemble it yourself.
My first advice is to wrap the new K&N (or BMC) in newspaper and let it sit overnight. If the newspaper is oil soaked the next day do it again. The number one problem with these filters is over oiling and then that oil getting on the MAF sensor. If that happens you will have to remove the MAF and clean or replace it.
Have a look at the air filter DIY here.
1. P1124/P1125 covers lean conditions (that the DME can not adjust for) at idle. P1128/P1130 cover lean conditions at close to full load.
2. Egas is not an option. It began on C4's (but not the C2) in 1999. All Carrera's have had egas since MY00. On the Boxster all 2.5' s do not have egas.
3. O2 sensors will deteriorate with age and either the sensor will stop sensing or the heater will not get the sensor hot enough. If you record your O2 readings using a scan toll you can watch the sensor deteriorate. Most folks just wait until a failing or failed sensor throws a CEL.
So is this a "Poser" or the "Real Deal"? ;) ;)
They are almost exactly the same.
If George is getting his soon then we can do both at once. If not at a work on cars day then you folks can drive down to beautiful Morgan Hill ;)
Sorry folks we can not post copyrighted materials here with out the copyright owners permission or the copyright owner putting their materials in the public domain.
Generically they mean:
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0175 System too Rich (Bank 2)
P0172 System too Rich (Bank 1)
Bank 2 (cyl 4-6) Sensor 1 (before the cat) and P0155 says that the O2 sensor is not heating. Unless the wiring harness has been damaged or the connection is corroded it is likely that you need a new O2 sensor.
1. They were about $450 when I bought mine.Folks, I am contemplating to have a 3rd radiator added to my C2 ( 1999) and I am wondering :1/ what does the radiator cost?
2/ what is involved in the installation?
3/ how much would installation cost
4/ what temperature drop could one expect compared with the stock 2 radiators?
The reason? I feel that the engine ( here in California) is running pretty hot ( gauge is indicating between the 8 and the zero of the (180) number and sometimes goes just on top of the zero number.
Cheers
HarryR
PS Loren, I just bought a B@M short shifter today ( eBay at $ 199.00 plus freight). I will be looking for your help :-)
2. See 3rd Radiator Install Instructions
3. About 4-5 hours labor.
4. See item 2.
Your current temp is normal. I bought mine for track days and fun runs through the mountains.
Clamp for Tips
in 996 Series Part Number Requests
996 111 108 00 Pipe Cover Clip - retail $11.73 each
