37,348 -
Days Won
537
Classifieds
Posts posted by Loren
Perhaps a pending fault since it is intermittent.
Don't forget about the crankshaft position sensor.
Lost Radio Codes
DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS.
Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. -
Left Front sensor -- 997 612 755 01 sender wire (pad wear indicator) US MSRP $59.28
Right Front sensor -- 997 612 757 01 sender wire (pad wear indicator) US MSRP $59.13
Sensors include cable and connectors... item 7
Rear (same for both sides) -- 987 612 676 02 sender wire (pad wear indicator) US MSRP $35.64
You can get better Porsche parts pricing through Sunset Porsche (board sponsor):
Factory Porsche Parts, Tequipment and Selection (Boutique)Genuine OEM Porsche Parts | sunsetporscheparts.com | Sunset Porsche Parts
WWW.SUNSETPORSCHEPARTS.COM
Find genuine OEM Porsche Parts direct from sunsetporscheparts.com at unbeatable prices. Also find Porsche Drivers Selection gear and accessories. Shop Securely Now. -
14 minutes ago, Matt Fussell said:
This thread is awesome! I need some help with my radio. The model is BE 2582. Serial number Y5007985.
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC." -
There are several brake options, different size rotors, etc., including ceramic rotors.
PM me your VIN and I will lookup which fit your brakes.
1 hour ago, Drhancur said:
I need a radio code for BE4462, serial number: Y5043167. Thanks.
Try 4350
What scanner did you use - that is not a Porsche fault code.
1 hour ago, villet said:
Hello,
I've got the same old story. My radio:
- CR-220
- Model: 4367
- Serial: X5018812
Any help would be much appreciated! 🙂
Try 5473
- 1
20 minutes ago, Tintin14 said:
Hi, I need help retrieving a code for Becker CR22 BE4367 Y5022055, any suggestions would be greatly appreciated
Try 1060
- 1
42 minutes ago, his15153 said:
Hi,
I'm hoping to get a lost radio code for my CDR -210 SN W5023523 from my 1999 996.
Try 8704
27 minutes ago, jim_hoyland said:
OK; I just had some 70K service done on my 2006 987, no problem.
But, in the recommendations box it says to replace the fuel pump and filter.
IDont understand how that could be recommended on an excellent running. 987 !
any thoughts ?
Your fuel pump and filter are inside the gas tank.
I would not go in there unless you are having problems. It's easy enough to measure the fuel flow should a potential problem arise.
As long as thay are the "big tube" design they will work on any 996 (as shown on Carnewal.com).
It is the "small tube" version that Porsche says to use only on 3.4 liter cars.
12 hours ago, vza said:
Do you know if it would effect any HVAC controls if I left in the display with the incorrect graphics.
Sorry, I don't/
Perhaps if your battery is low and it is on a long time. But in most cases it will turn on and slowly charge the battery then turn off until the voltage falls to a certain level. So once established in should only go on about once a week.
3 hours ago, waka76 said:
Thanks Loren but I'm looking for an original Eisenmann PSE approved for road use (OEM version).
These exhausts all have the same reference number except for the last two digits and I can't figure out which references to choose (00, 04, 05...) that are compatible with a 996 4S (and if possible with big tubes)..
On one site, I'm told that they have the part number that ends with 05 "big tubes" for a great sound (112dB). But do all 05s have a big tubes ? On another site, I see one ending in 00 but I don't know if it's a big tube and if it's compatible with a 4S...
What Carnewal sells is OEM Porsche parts.
I doubt there are any small tube exhausts left that are new. If order from a Porsche dealers their parts list will always show the latest updated part number and I think the big tube exhaust has been around since 2002.
7 hours ago, Lombo1439 said:
Hi Loren:
Your help would be greatly apprecaited. I have a 2000 Boxster S with model 4462 and serial number X5037854. Third owner, disconnected the battery and didn't even think about radio security...Again, thanks,
Dave
Try 9079
33 minutes ago, Jeeplife said:
Hi Loren,
I need your help again please! last unit crapped out - got a replacement but no code with it.
Model :CDR 23 / BE 6611
Serial : 25012749.
Thanks again!
"CDR-23 (or later):
These radios do not have a security code - that is, not that the user enters.
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."- 1
1 hour ago, Jack5j said:
Hi,
I repurchased a '97 Base that I sold a few years ago. No manual came back with it, though.A CDR-221 Ser#5007697 Model BE2282? The code was in the manual
Thank you!Jack5j
Try 0765
- 1
1 hour ago, fitswell said:
Hi, could you help with the code to my Boxster’s Becker CDR 220?
serial-no: Y5037062
Try 5271
Most US/Canada cars had AC standard. In many other countries AC was an option or was under manual control only.
Front bumper cover removal to replace horn
If you look at my third radiator install DIY the first part deals with front bumper removal.
