37,357 -
Days Won
540
Classifieds
Posts posted by Loren
Yes to both. If the cable has not been moved or a shorter shifter installed then it is likely (bad news) the transmission.
The parking brake uses two drum brakes that are on the inside of the rear brake rotors. There is a typical drum brake adjustment (for the shoes) on each rear rotor. Adjust with a large screwdriver through the hole in the rotor hub (wheel off). Rotate the adjustment until the rotor can not be turned then back off 5 clicks (rotor should turn freely).
The parking brake cable is adjusted in the center console by removing the plastic plate in the storage bin. Using two wrenches release the lock nut and then tighten the nuts to adjust the cable. A correct adjustment will NOT actuate the parking until 5th click. Anything may cause the brake shoes to drag and cause premature wear on the parking brake shoes. Don't forget to tighten the lock nut again when your adjustment is complete.
I have not done it but it looks like if you remove the front wheel and fender liner - you should be able to see and get at everything.
Which spoiler are you getting? Most replace the whole deck lid.
You will need a new wiring harness since the new spoiler will have a fixed wing (so the light won't stay on). Discussed here
Changing over between Kilometers/Miles (or Miles / Kilometers) is easy.
With the ignition on, hold the right hand adjustment button (looks like a clock) turned to the left for about 5 seconds.
(BTW... this is in the Owners Manual)
Tell us which ones you need and we can look up the part numbers...
Concern #1: Now I know this car HAS to be hard to work on, right?
Concern #2: From what I have seen so far, parts appear to cost on average about double what the BMW parts are. Does this sound about right?
Concern #3: I have been buying BMW parts online. What is the best source for Porsche parts?
Concern #4: You can find the Factory BMW shop manual on e-bay doing a search on ETK TIS CDROM. Is there anything like this for Porsche?
Concern #5: I believe I resolved this concern by stumbling upon this forum. I have looked at several Porsche DIY forums, and you guys seem to be the best group on the web!
1. IMHO - no, oil change 15 minutes, spark plugs 30-40 min. Brakes are big and easy to change.
2. Like any make/model it pays to shop around. RennTech.org trys to help our users by providing links to folks like Sunset Imports that sells Porsche parts at dealer cost. See the red link at the top of the page.
3. Same as 2.
4. Many DIY questions are answered here including pictures, and 1st hand tips. Some members have also done a set of DVDs on common upgrades and maintenance items. Check them out in the RennTech.org Special Offers Forum.
All the talent and experience of the many members here is what makes RennTech.org a cut above all the rest!
Good luck on your purchase decision!
Many times they will vibrate or rattle when sitting still and just racing the engine. If it rattles then - let the dealer hear it.
There are two kits. One for 3.6 liter (MY2002 and newer) and one for 3.4 liter cars. The 3.4 liter kit was never offered for sale in the US and may be very hard to get. I have seen prices for both kits between $8000 and $10,000. Installation requires removing the engine and a partial disassembly - including changing the cylinder heads and camshafts. The (3.6 liter) install TSB estimates about 26 hours for the work.
Replaced by 996 111 121 06 then by 996 111 121 07 for all (non S) through MY99.
(Funny a Boxster has a 996 part number for a muffler that could never be used on a 996) :lol:
996 606 160 01. It is an expensive part.
$244.19 Retail (as of Nov 2003)
If there is no set crew then it just pulls off. Try twisting it as you pull - oh - and open the top in case it comes off with a snap ;)
Wheel size is usually next to the valve stem on the outwards facing side of the wheel. Porsche part numbers can usually be found on the inside of the wheel. If you can get the part numbers I can look up the offset.
As long as the wheels are 52 mm (7.5" or 8" front) and 63 mm (10" rear) offsets they should fit without spacers. The 10" rears with 40 mm offset will also fit a MY97 C4S.
996 603 012 03 Alternator $558.69 (retail as of nov 2003)
Looks like about 1 hour from the shop manual.
This is not brain surgery - you might want to try an (experienced Porsche) independent shop.
All cylinders misfiring has to come down to one of the following:
wrong spark plugs
bad gas, plugged fuel filter, or fuel pressure too low
air intake leak
Amsoil is not an approved oil by Porsche - nor is 20W-50.
All Porsche approved oils are 0W-40 or 5W-40. Commonly available (approved) US brands are listed on my DIY Oil Change page here
Sounds like a bad radio or amp or even a loose or broken wire.
Most of the TSBs are for primarily the PCM2/Bose systems and that was a software update.
There was one delivery issue (TSB 6/02 9120 Activating the CD Radio "Porsche CDR 23" dated 10-11-2002) where the CDR23 was not activated (correctly) by the dealer during delivery prep. They need a PST2 (software ver 14.0 or newer). Earlier versions of PST2 software caused "Impairment of the sound quality due to false vehicle coding of CDR23 and amplifier."
On the rear the kinematic toe-in is not adjustable. Camber and toe can be adjusted via eccentrics. A adjusts toe and B adjusts camber.
Tool B (Porsche tool 9626) below is used to get at the right angle for the rear eccentrics.
Yes, they will include all groups.
To be caught up you would need to order 40 through 94. The old prices were $8 to $9 each (retail).
All of the supplemets start with the original part number WKD-483-721.
So each supplement would be an add on number WKD-483-721-92.
You need to look at your last supplement number and get all the supplements from that number to current (94).
http://www.pca.org/panorama/sample_article_3.html
A PDF version is also available at the link at the bottom of the article.
You can find Gert (and his Porsche products) at www.carnewal.com
I have the part numbers but no details.
997 613 225 00 A05 Garage Door Opener Switch (left hand drive)
and
997 618 227 00 Control Unit Garage Door Opener
and
997 618 257 00 Support Bracket for Garage Door Opener Control Unit
Coolant boil-over
in 986 Series (Boxster, Boxster S)
Read the part number on your cap. If it is not 996 106 447 01 then you need a new cap. $14.71 retail as of Nov 2003.
