37,340 -
Days Won
536
Posts posted by Loren
11 hours ago, Alan Ko said:
Wouldn't i at least get power to the unit? i.e. some lights or even a porsche logo?
Not if the network does not see it.
12 hours ago, Marauder said:
Good Evening Loren, could you please provide the radio code?
1999 Porsche Carrera 996
BECKER CDR-220
SERIAL: W5011091
TYPE: 4462
Thank You For Your Help!
Try 4132
- 1
Engine M 96/03
General
The engine for the 911 Carrera in model year 2002 is a further development of the previous engine.
During the development of this engine, particular attention was directed at reducing fuel
consumption while simultaneously increasing engine performance and torque.Summary of modifications:
- Crankshaft - bearings and stroke
- Crankcase
- Pistons with Graphal coating
- Valve gear
- Cylinder head
- Valve stroke control on intake side with axial variable camshaft timing (VarioCam Plus) -
4 hours ago, BillWing said:
Any thoughts on my 2003 996 car key remote feature not working? I replaced the battery which made no difference.
Thank you for any considerations you may offer.
Bill
10 year old car - is the button worn so much it does not "click" anymore?
If so, then the contact of the button to the circuit board is worn out.
The simplest fix in to by a new key remote and transfer your physical key AND your transponder pill to the new remote.
Porsche sells a nice design key for that purpose and it requires no programming if you transfer the physical key and transponder.
3 hours ago, Mikco said:
Hi!
Continuing this old thread with a new problem;
I`ve got a 996 manual my2000 that is being under built. It is originally 3.4l and has had a DME 99661860400 which is now broken and I don`t think it can be fixed anymore.
Well I`m swapping the engine now to m96.04 3.6l MY2001. My question is do I need an DME 99661860500 and will it be able to function in this body?
Also the original key of the car is missing so I`ll be having some immobilizer issues in any case once I get all the parts needed.....
Hope someone could give me some information for this situation!
Yes, you will need the DME for a 3.6 as the varicams are different. You will need a PIWIS to re-program it to your car. Likewise with the keys/immobilizer they will likely need to be re-programmed also.
Radio or PCM units have to be adopted using PIWIS (Porsche diagnostic tool).
They slide into the open end of the rails (U shaped).
2 hours ago, milljt said:
Hello,
Becker CDR 220
SN X5031279
Thanks!
Appreciate the help.
Try 2795
PM me your VIN and I will look up your wheel color.
7 hours ago, William Alderisio said:
Looking for radio code 99 boxster
Becker 1 cdr220
type 4462
serial # X5013401
Thought the code was 0506, but it didn’t work
thank you!!
Try 0560
Hards to say from the photo but they kind of look like the seat rail protection that goes on the front of the seat rails.
1 hour ago, T M said:
2000 boxster S
serial # y5038096
type 4462
Thank you
Try 5353
Are you sure the temperature sensor is connected?
5 hours ago, Loriana said:
X5031052
Try 0326
5 hours ago, Paul Choi said:
I am trying to change my retractable, spoiler deck lid to a fixed wing spoiler deck lid. I purchased a Porsche wiring harness 996.612.070.04 to connect up the new spoiler. Unfortunately, I do not know where to connect the other end of the wiring harness.
Does anybody know where the other end of the wiring harness is located?The connector should be on the right fender in the engine compartment.
3 hours ago, Kelly Finn said:
I've owned my 2006 S for about 1.5 years. The whole time I've owned it, the overhead interior lights haven't worked. The footwell lights, door lights and the lights in the ceiling of the rear hatch area all work fine. I pulled up the wiring diagrams and checked all the fuses shown. All were good. I decided to check the rest of them and found a 5 amp fuse blown in position 27 of the LH interior fuse block. I replaced it and all the interior lights work as they should. Every fuse diagram I've found shows position 27 "not used". There are 2 contacts in that position, so it's definitely an active spot. The fuse diagrams for the 2006 on Alldata, are labeled as 2004. The diagrams I've found online are rather generic and identified as 2003-2010, or something similar.
Is there a factory wiring diagram specifically for the 2006 Cayenne S?
I sent you a PM.
3 hours ago, 986DB said:
Just got a 986 and I’m lock out
Radio serial number: Y5042561
Radio type: 4462
thank you in advance
Try 1013
44 minutes ago, rliberty said:
Hi All! I have a Becker CD-2 from a 1992 964 C4 and I have lost the code. Can anyone help?
Serial number: A0614401
Thank you!
Robert Liberty
502.533.4996
This is a radio not a CD player serial, right?
Not sure that's pretty old.
Try 7289
2 hours ago, TJ said:
Hello guys,
My radio is a CR-220 Becker 1
Type: 4362
Serial: y5021061
Build Date: 47/98
Thank you so much in advance!
Try 0298
3 hours ago, RyanCharlie said:
Thank you but 2109 didn’t work
any other thoughts?
Did you use the procedure in the Lost Radio Code FAQ?
If not, then your radio may have been repaired and the serial number changed (electronically.
If you did use the procedure and the code I gave you does not work then it is likely that the radio was repaired by someone other than Becker - in that case I can not help you.
1 hour ago, RyanCharlie said:
1998 Porsche Boxster
Bought car a year ago and haven’t been able to get the radio working since because of this radio code issue. We have tried 1209 based on what one service tech told us but it doesn’t work. Hoping you can help! Thanks!
becker
cr210
serial number: V5007001
Try 2109
Lost Radio Codes
DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS.
Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. -
4 hours ago, BadBilly83 said:
Hello Porsche friends,
I need the radio code for a 2001 Boxster I just bought for my son.
CDR 220
Type 4462
CDP 2081
24/99
serial 15076106
thanks,
Bill
Try 9397
CDR23 Enable CD Changer
in 986 Series (Boxster, Boxster S)
Did you connect the correct fiber optic cable?
They are different depending on whether you have the amp or not.
After all the cables are connected you will need a PIWIS (or Durametric) to adopt the CDR-3 to your car.
