37,335 -
Days Won
535
Posts posted by Loren
MY02 Coupe -- 2 wheel drive -- 6 speed -- RoW M030 Sport Suspension Parts:
Front
996 343 041 18 -- Shocks
996 343 531 19 -- Coil Spring (set of 2), color coded Green/White
996 343 701 04 -- Stabilizer (swaybar) (23.6 mm)
996 343 511 00 -- 3.0 mm compensation plate
or
996 343 511 01 -- 6.5 mm compensation plate
Rear
996 333 051 22 -- Shocks
996 333 531 26 -- Coil Spring (set of 2), color coded Green/White
996 333 701 17 -- Stabilizer (swaybar) (19.6 mm)
996 333 105 03 -- Additional Spring (bump stop 13 mm shorter than stock)
996 333 511 02 -- 0.5 mm compensation plate
or
996 333 511 03 -- 4.0 mm compensation plate
Gary,
1. There are different suspension parts for almost all model differences (i.e coupe, cab, 4 wheel drive, 6 speed or automatic). To get the right suspension parts I will need to know: model year, body style (coupe or cab), 2 wheel or 4 wheel drive, and 6 speed or Tiptronic. The differences are subtle in most cases but I think you do want the suspension parts Porsche designed and tuned for your car.
2. Yes, there are spring compensation plates. The spring compensation plate you need is easy to identify because Porsche uses a color code on the spring itself. For example, on the front springs you will find two bands of color (like green - white) together that tell you what spring model version (like RoW M030). There is also a third color band (on a different coil) that tells you the tolerance group the spring is in. This code stipulates the spring compensatotin plate to use. For the front is: White = 3.0 mm compensation plate or Green = 6.5 mm compensation plate. On the rear the color codes are: White = 0.5 mm compensation plate or Green = 4 mm compensation plate.
FYI... the shocks also have a color code that tells which suspension they belong with. For the front shocks (White dot = standard suspension RoW/USA; and Green dot = sport suspension RoW/USA). For the rear shocks (Brown dot = standard suspension RoW/USA; Grey dot = sport suspension USA; and Green dot = sport suspension RoW).
Yes. If you follow the belt down to the carpet there is a large bolt under a plastic cap. Remove the plastic cap and then remove the bolt (remember the order of any washers or spacers). This should allow you to manipulate the belt through the rose.
Pics would be great and if you have any dimensions on the mounting plate that would be really helpful too.
Thanks! :cheers:
This likely needs some testing but give it a try (if you want). Door Panel Removal/Install Instructions
Is it the lead that plugs into the relay sockets?
Yes you can likely get it in Savanna. But, as Gert said we need to know the type of seats (sport, comfort, or standard).
p.s. We know your car is a MY99 Cab ;)
Note:
- The following values relate to the empty weight, i.e. full fuel tank, vehicle with spare wheel/collapsible wheel and tools, but without driver and without additional weights.
- X74 = 30 mm lower. This can be identified by 1 yellow mark on the shock absorber.
Note:
- A caster adjustment is normally not necessary and is therefore not present! If required in a customer service matter, a caster adjuster may be installed (Serv. No. 40 19 23/Installing caster eccentrics).
- The toe-difference angle value is also influenced by the vehicle height! For this reason the measured result must be evaluated accordingly! No action is necessary in the case of small deviations from the toe-difference angle required value, as long as the value to the right and the left is almost the same.
Joel Reiser just answered this question at the PCA website. (BTW... 986 and 996 use the same coolant). Here is what he had to say about coolant:
When I was racing a Porsche GT1 some years ago, they said the coolant had to be special, and it came from Audi dealers as the standard coolant they carried. I don't know what the issue was, but that was easy enough, so I never thought about it too hard. This same situation has carried over intact to the the 996 and the 996-based GT3 race cars. The only difference is that Porsche now carries the coolant with their own labelling.The most often cited issue was to do with keeping the water pumps happy but I have no details on what the exact issues were.
The stuff sold by Porsche was made or at least imported by Elf in Warsaw Poland from Elf in Antwerp Belgium. It is 100% organic according to the label, ethylene glycol based, and has been sold for some years under Porsche part #000.043.203.78. More recent product batches (with same part number) now have a Porsche label, and the origin is the same address in Belgium, now from Arteco NV, so either Elf spun off that plant, or it was always just buying from there, and the private labelling agreement with Porsche was changed to drop the Elf brand name from the supply chain.
This coolant also has the property of being approved by Porsche, a factor not worth overlooking. Should you have a 996 cooling or water pump problem down the road, it would be better to have receipts from a Porsche dealer for their coolant, rather than the prior savings of a few dollars.
Joel Reiser - PCA WebSite - 7/14/2003
The front bumper removal and installation is covered in my DIY for the 3rd Radiator Install. This should have everything they need. Be sure and get some before and after pics! :jump:
Model -- Manual -- Tiptronic
Boxster -- 2811 -- 2936
Boxster S -- 2911 -- 2993
Carrera (Coupe) -- 2959 -- 3080
Carrera (Targa) -- 3119 -- 3240
Carrera (Cab) -- 3135 -- 3256
Carrera 4 (Cab) -- 3267 -- 3388
Carrera 4S -- 3240 -- 3361
GT2 -- 3168 -- n/a
GT3 -- 3043 -- n/a
TT -- 3388 -- 3487
Carrera GT -- 3042 -- n/a
Cayenne S -- n/a -- 4949
Cayenne TT -- n/a -- 5192
Note: all are MY03 except GT3 and C GT which are MY04
Chad,
Here is a link to a large (2.5 MB) PDF file for steering wheel removal and OBC hack. You may not need the OBC hack but the steering info is good.
The tank is on the right (passenger) side of the car.
My understanding is you would need to drain the oil from the bottom of each turbo and that it is an 8 mm hex bolt. Sorry, I do not have a picture or diagram. I'm trying to arrange to take pics with a local guy on his TT oil change. BYW... even after draining all three there is still 4 liters of oil in the engine.
IMHO Yes. Here is why I think so...
The X51 beefs up the engine, oil system and cooling. Here is a short list:
- new intake manifold with modified cross-section (material: sand cast aluminium );
- new intake pipe supports adapted to the form of the intake manifold;
- new exhaust manifolds with larger cross-section and optimized flow behavior;
- new cylinder heads with optimized, CNC-milled inlet ducts;
- new camshafts with larger valve stroke on the inlet side and modified inlet and outlet timing;
- inlet valve springs adapted to the enlarged valve stroke;
- modified partition box in the oil pan;
- modified maps for the DME control module.
- new underside panel in the transmission area;
- additional radiator in connection with modified front spoiler, except on the 911 Carrera 4S (996).
or you could always go with the new GT3 where you get the base for the R and RS racer cars... or better yet a cup car ;) wait I guess that is not streetable... darn :rolleyes:
JayM,
I sent you (via email) a link to a draft of TT oil change instructions. Have a look and tell me where it can be improved.
Thanks! :beer:
Ben,
3.4 liter or 3.6 liter?
Option on a new car? or add on to existing car? :huh:
Jonathan,
Here is an online source I found. Not the least expensive but they do have stock and free shipping.
Jonathan,
If you look at his pictures... the original (Porsche) battery has the positive terminal on the passenger side of the car closest to the windshield. When the guy in the article mounted the Optima Red Top battery the positive post was still on the passenger side but to the trunk side. So, my point is that if you got the Orange Top Reverse Post battery the posts would be in the original postion (passenger side - closest to the windshield)... perhaps allowing you to use the existing cable. Or maybe it is still too short... we won't know till we try ;)
BTW... I agree with the centering of the battery on the plate.
Updated August 18, 2003
Here is an updated list of TSBs for the Cayenne:
03.. 2/03 Control Unit Replacement/Software Update 5-23-03
0335 2/02 Voltage Supply During Diagnosis 2-28-03
0335 0305 Creation of OBD II Reports 6-27-03
9660 4/02 Battery Disconnect Switch 2-28-03
1001 2/02 Engine Repairs 2-28-03
1701 3/02 Engine Oils Approved by Porsche 5-23-03
2706 2/02 Battery Charging During Workshop Visits 2-28-03
2706 3/02 Battery Maintenance Checklist 3-7-03
2706 1/03 Auxiliary Battery For The Cayenne 2-28-03
2706 2/03 Auxiliary Battery Omitted 6-27-03
3735 2/02 Tiptronic Repairs 6-27-03
3965 3/02 Transmission Repairs 2-28-03
3965 2/03 Approved Oils - Final Drives and Transfer Case 5-23-03
4316 1/03 Level Control System Control Unit 2-28-03
4316 2/03 Level Control System Calibration 2-28-03
4440 2/02 Summer Tires and Wheels 2-28-03
4440 3/02 Winter Tires and Wheels 2-28-03
4464 7/03 Spare Wheel Cover Installation Instructions 7-25-03 *
6331 7/03 Cleaning Rear Bumper Stainless Steel Protective Strip 5-23-03
6692 3/02 Roof Box For Transport System 2-28-03
6692 5/03 Surfboard Rack For RTS System 6-27-03
6692 6/03 Bike Rack For RTS System 6-27-03
6832 4/03 Cool-Bag Installation and Use Instructions 2-28-03
6845 3/03 Luggage Partition Grill 2-28-03
6845 1/03 Cayenne Cargo Organizer System Installation Instructions 5-23-03
9110 3/02 PCM2: Start Screen Visible For A Long Time 2-28-03
9112 2/02 PCM2: No Destination Input Possible 2-28-03
9294 7/03 Rear Window Washing System Spray Nozzle Drip 7-25-03 *
9666 3/03 Entry & Drive System Fault Types 5-23-03
9666 5/03 Remote Control For Central Locking System Not Functioning - Engine Shutdown Not Possible 6-27-03
* New this month
** Updated this month
Well, there is are two TSBs for this so your dealer may still do it for free. Certainly worth asking about.
If you want the TSBs with the part numbers and instructions, email me or join the forum so I can email you.
Thanks and welcome to RennTech!
Specs on the 34R Reverse Post Orange Top (identical to the 34/78 Red Top):
Volts: 12
Amp Hours: 55
CCA @ 0° F: 750
CCA @ 32° F: 980
J240 Life Cycle: 10-12,000
Deep Cycles: ~50
Reserve Minutes: 104
Physical Size L" x W" x H": 10 x 6.8 x 7.8
Weight Lbs.: 38.8
Ok, your oil change page is ready for testing... Gt3/TT/GT2 Oil Change page
I am not sure on the engine drain plug part number -- please verify with your dealer (and let me know).
Also, let me know the wrench sizes if you can...
ROW M030 PN for MY02
in 996 Series Part Number Requests
Gary,
See my first post... there is a tolerance code on each spring that is used to define the proper compensation plate. You won't know what that is until you get the springs. Plus -- there is a 50-50 chance that it is the same as what you already have. If not, you will need to get the correct one. Most installation/alignment shops can take care of this for you.
BTW... who are you buying this from? Gert at Carewal.com has done many of these. I recommend him.
