37,350 -
Days Won
538
Classifieds
Posts posted by Loren
Yes, it is basically re-flashing the program memory of the ECU. Certainly worth a try.
Each ECU must be programmed to the car - no straight swaps.
Did anyone try to reprogram the ECU?
I would certainly do that before buying a new or used ECU.
10 hours ago, mrsandman said:
had to disconnect the battery and lost my radio code. here is my vin #WP0CA2986XU624676
my 1999 Boxster
Thank you for the assistance
Blake
Your VIN does not have any radio info. We need your radio serial number.
From the Lost Radio Code FAQ ...
"How to get your radio serial number?
CR-220/CDR-220:
Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
Or, if the radio is out of the car the then the serial number is on the label.
CR-210/CDR-210:
Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
Or, if the radio is out of the car the then the serial number is on the label."
1 hour ago, Jerry A Higgins said:
I have a CDR220 radio in my 911 Porsche and need the code. The see No is Y5033762. Thanks
Try 8609
4 hours ago, arethusa71 said:
Hello. I need a code for my Becker CDR-220 serial number X5035057
Hope you can help!
Thank you.
Try 9195
- 1
6 hours ago, adamjachec said:
Halo,
can You please help me with the radio code for 2001 Carrera4
CDR-220
Y5052042
Type 4462
Send please per E-Mail adamjachec@gmail.com
Thank You very much
Adam
Try 9141
7 hours ago, DelaveagaSC said:
Hey Loren
Ive got a CDR-220
Serial # 15076183
Thanks in Advance
Try 0828
You need a Porsche specific scanner to read the fault codes (like Durametric or Porsche PIWIS).
A double beep means that you have more than one zone with a fault ot the alarm control box has failed.
Get the car scanned for fault codes.
1 hour ago, drubes said:
Hi I am new and hoping you can help with a code.
I have a CR-210 with a serial number of V5005206.
Any help would greatly be apreciated.
Thank you!
Try 4786
Looks like your speed gong is enabled.
5 hours ago, Tommygee said:
I love you. That worked. Is there anywhere I can donate to you or the website for this?
Feel free to donate
3 hours ago, Tommygee said:
02 C4S
cdr-220
type: 4462
serial: 15005339
help please!! 🙏🏼
Try 3019
27 minutes ago, Gerhard Schiller said:
Hi,
same here. Took delivery with battery disconnected. No code.
Becker CR220
Model BE4362
Serial 15032048
Any help with getting code would be appreciated.
Try 0104
Which airbag?
What fault code(s)?
P0068 Mass air flow implausible
Totals fault
One or more additional faults are entered that more precisely indicate the operating ranges in which the fault occurred.- Near idle speed range:
- P1069 + P1070 + P1071 + P1072 + P1073
- Lower partial load range :
- P1074 + P1075
- Upper partial load range :
- P1076 + P1077
P1023 Fuel pressure/quantity too low at start
Possible fault causes
- Short term failure of the engine speed signal as a result of a crankshaft sensor fault with or without a corresponding fault entry
- Predelivery quantity or pressure in the fuel low pressure circuit too low
- Quantity control valve faulty (in fuel high pressure pump)
- Fuel high pressure pump faulty
P1026 Fuel high pressure implausible
Possible fault causes (see Fault setting condition(s))
- Below limit value:
- Fuel tank (driven) empty
- See extended fault memory
- Actual value 40 Fuel Level Input [0%]
- Below limit value or above limit value :
- Insufficient fuel due to foreign bodies (chips) ahead of the fuel high pressure rail
P053f Fuel high pressure after cold start
Based on what I see for faults here I would investigate - the fuel pump pressure and flow rate.
6 hours ago, Martin Zhang said:
I just bought a 1998 Boxster, and I would appreciate your help in obtaining the radio code.
CR-210
R 3297
Serial: V5007550
Thank you!
Try 1496
You will need a Porsche PIWIS tester ($18,000/year to lease) and your cars IPAS codes (from a dealer).
Or a shop with a PIWIS should be able to do that also.
1 hour ago, Antho said:
Hello,
Recently just purchased a 2000 boxster, but it didn’t have the code for the the radio.
CDR 220type: 4462
serial: Y5040575
Thank you!
Try 0505
1 hour ago, BBBennett said:
The PDF link does not appear to work. is there anywhere where i can find a write up for this with pictures? i need to do the speaker? also is there a direct link for a speaker that will work?
Try sending a message to the original poster.
51 minutes ago, MrSpeedyPants said:
I can't offer advice on launching but I have a 996 that Ive had in the mountains a bit. I found that if I am aggressive enough with the gas pedal the car will stay in a hi-rev gear.
I'n beginninng to think that I dreamt this but I read that the tipronic has 7 different driving modes. I'm looking to find out about that if anyone knows.
Sorry, only 6 modes...
1 hour ago, jeff Vidon said:
Hello,
Could you please help me with the code for this radio cdr 220.
I bought thos boxster S recently and the code wasn't provided:
CDR 220
Model: BE 4462
Serial: Y5051821
Thanks in advance !
Jeff
Try 7620
I've had the XPEL on my Macan GTS for over six years and it is holding up real well.
I did full hood, door handle (finger grip area), as well as fender surrounds and back bumper .cargo lip.
No yellowing that I can tell and the only place it came up a little is on the front bumper where someone"tapped" me. The bumper is fine but the XPEL came up a little from the impact.
I do not have any experience with the Hexis.
11 hours ago, htech4739 said:
HI! I have a radio code request, hopefully someone can help me here, as the dealer refuses to look it up by the serial number..
Model BE1492
Serial R1033347
Long serial number 1492bw0r1033347
Sorry, I can't help you with a Mercedes Becker radio.
Lost Radio Code - post your request here
in Lost Radio Codes
Try 6910
