37,316 -
Days Won
532
Posts posted by Loren
In the service manual they actually suggest warming the engine first.I think I know why the black plastic finger tubes are replaced along with the rubber o-rings. When I removed the ones from my car, they cracked :angry: so re-using them might not be an option unless you are more skilled than I am when removing them from the engine.Note -For disassembly "Removing oil protection tube", the cylinder head cover in the vicinity of the oilprotection tube must be heated up. Two different methods can be used for this:
First method: Heat cylinder head cover in the area of the oil protection tube using an industrial hot-air gun.
Second method: Warm engine up to operating temperature.
The second method is preferable if no further assembly work has to be performed, e.g. sealing cylinder head cover, replacing tensioning element (VarioCam)or replacing the flat-base tappets, etc.
Most common are the center armrest console and the front trunk.
Should be fixed now.The link to the owners manual dosent work!!!! -
IMHO no. I think you want a suspension expert to really look through the car for any other (hidden) damage. If that cross memember is damaged then you could have other damage including several cracked or nearly sheared bolts on other suspension components. I think at least a partial disassembly would be needed to ascertain the damage.Loren, the second page of the rear suspension view shows the cross member brace (#6) and that is what is bent. Is that something that could bend without other things bending? -
Replacing is the front fender (wing) is not too difficult. The rear panel from behind the door all the way back to the bumper is one piece welded under the rear side window. If you damaged the rocker panel (side skirt) then that could be replaced also - but any rear quarter damage means body work.
Do you have a pic or two?
The CD Changer goes through a firewall grommet that is not really behind the battery. Follow the cable laying over the trunk seal in this pic.I'm going to get my camera and bring it to work tomorrow and take how to and where to pics. I don't think running wires to the bonnet will be the best thing for you to do. The only hole in the firewall is directly behind the battery. If you run the signal wires past the batt you will most likely get some interference(engine noise). Sub under the seat? I have a bunch of great ideas as I am finishing my 99 996 show car. By the way.. this is what I do for a living(image courtesy of Tom Morris)
The Aerokit Cup rear wing has two sets of screws.
Item 16 (900 249 034 02) holds the adjustment plates on the side of the fixed portion of the wing. Item 18 (900 249 041 00) hold the moveable wing in the adjustment plates. Always use Locite (or some other thread sealer) on all the wing screws or they will vibrate out.
Porsche does not recommend X74 on cars before MY02 when they added stiffening to the chassis.Will the X74 suspension components fit on a 1999 996? -
As of the July 9, 2004 TSB no 15W-50 oil approved.Tool Pants....I meant to ask you....do you know if Mobil 1 15W-50 is still on the approved oils list?
Only the following weights are approved and not in all brands:
0W-40
5W-40
5W-50
The switch for cruise control is on the clutch pedal. In non-egas (MY99 C2 only) there is a seperate control box for cruise control. On MY99 C4 and all later 996's (egas) the control is in the DME (DME 7.2).
Harry,
The shocks don't make a sport suspension - the springs do. You need to find the color bands on the springs. There will be three color bands - the first two are spring type and last one is tolerance for the spring plate. They will likely be brown and white (standard springs) with a tolerance color of green or white. So your colors may be: brown/white/white.
Tell me the spring band colors and I can tell you what they are.
I think all steering wheels are leather covered on 996's. The second one is plain (no aluminum). The leather vs. leatherette is a matter of taste and upkeep/care. If you have a lot of leather in the car (i.e. large or small leather package) then you might want to stick with leather.
Here is a pic of mine in leather.
You've got mail...
996.347.983.29 A28 Black Steering wheel with Aluminum Look/Leather - MY03 on
996.347.804.64 A28 Black Steering wheel - MY00 on
Don't forget to order a 3 spoke air bag - the steering does not come with one.
I believe the "K" means special order. You might try Gert at Carnewal.com since these only show on the RoW parts list.
Deck Lid
K 996 512 991 94 900 cover (in carrara white) with air box
Spoiler
K 996 512 959 94 spoiler
K 996 512 983 94 plate /Left
K 996 512 984 94 plate /Right
K 999 073 334 00 round head screw M 6 X 16
955 505 683 00 Grille (V6 and S only)
We have added 8 new skins to the RennTech.org. Now you can take you pick: Refault Blue (default), Ashes to Ashen (Black), Bloody Knows (Red), Bubblegum Shoe (Pink), Olive You (Green), Orange You Glad (Orange), Plum It (Purple) or Tanned Hide (Beige).
Just choose your favorite skin with the chooser at the bottom left of any page. A cookie keeps your setting.
(Opps... should be working now.)
I doubt you can get the cat clamping sleeves anywhere but Porsche. My parts list shows them at about $30 each (996 111 220 01).You might want to try new clamps. I seem to recall a similar issue when I installed an aftermarket exhaust on my 996. I replaced the clamps with new ones and the problem went away. If I remember correctly, the new clamps didn't cost much.Karl
Were the new clamps just generic ones, or specific Porsche ones?
Just click on Donate to RennTech.org here or at the top of any page and follow the instructions.Since I like this forum here very much I would like to contribute.Please tell me how and which amount you would like me to contribute.
I am a Paypal user.
Best regards,
G. Cameron
Just follow the 996 DIY here. It is the same process.
Brown/White is ground on the left side and Brown/Blue is ground on the right side.
All of those codes are consistent with no secondary air injection - so that is where I would start. Check the fuse, relay, and then start checking the wiring at the pump and vacuum fittings.This is my problem:I took a trade in 1998 Boxter with 53k
During my first long drive the check engine light came on.
I inspected the car and found a hough crack in the gas cap and replaced it with a brand new one from the dealer. Before just going and resetting the light I read the codes and got 1124, 1126, then I reset the codes and drove it for about 15 more miles, the light came back on again and got the same exact codes. I added a full tank of gas, reset the codes again and drove for two days with no problems. Then again today the light is back on, I read the codes and please pay attention to the order I got the codes in: P1126, 1124, 0410 secondary air sys, 0130 OS sensor bank one sensor 1.
Could it simply be a bad OS sensor ?
I am going crazy with this car please help.the :angry:
Contributing Members can view this document (and others) online...Could anybody please also post the 14 page document on the hardtop problem to me ?I have got a 2001 996 and the hardtop rattling is just driving me crazy. :-(
Thank you very much in advance!
My email: Dr.Cameron@email.de
Difference in Exhaust System between X50 and TT?
in 996 TT, 996 TT S, 996 GT2
There is nothing in the parts list that signifies the GT2 muffler is used for X50. The GT2 muffler is a different part number but I do not know the differences.
Oh... and my 1 year old price list shows it at $2869.42 not the $7000 he mentions. If it came off a GT2 then the part number should be 996 111 987 72.
