37,308 -
Days Won
530
Posts posted by Loren
986 606 125 00 replaced that sensor in April 2000 then it uas updated again to 986 606 125 01. I don't know the Bosch number but someone should be able to cross reference it.HiOkay, I'm having a tough time finding this part online. The MAF serial numbers are:
0 280 218 009
996 606 124 00
This part is for the 2000 Boxster.
I can't find this part number online ANYWHERE. I find a bunch of MAF's, but I'm not sure if this one is discontinued. I've figured out (I think) that its the old version of the MAF.
Now the question is trying to find one! The Parts Bin doesn't have any of these numbers on their website. I even called Bosch, but the reps haven't gotten back to me for a while.
Any help would be great. If I can't find this part, how much should I expect to pay to get the DME reconfigured to work with the new sensor? I'd like to get this problem solved as soon as possible.
-Kevin
30 minutes at the most. Detail are in my 3rd Radiator DIY
I believe that SmartTop (as well as the Bahntech solution) are only for Boxsters. The 996 top control is much more complicated - it does not use a relay but a separate control box.As scouser points out, a simple "timed" relay does not suffice. The controls are a little more complicated. Essentially, it works analogous to the window controls (stop/start/auto/manual), with speed, latch and other controls added.SmartTOP (SmartTop Webpage) has a nifty relay replacement solution that just plugs in and has everything integrated. They are the most expensive solution at 228 Euro (185 Euro in group buys).
Bahntech is the cheapest solution ($145) and does it with a custom printed circuit board that "hangs" between the dash buttons and the actual inputs to the relays. For it to work as desired you need to plug in the speed sensor wire and perform the two relay hacks (disable handbrake and speed signal).
I have the Bahntech in the 986 and am quite satisfied with it. Roll-your-own is doable, but probably not worth the roughly extra $100 you might be able to save. If you consider going the smartTop "clean" approach, be aware that just the relay replacement switch is $70 for starters :(
I don't think the Bahntech unit is "timed", but rather it uses the signal from the metal hood cover when it closes (same signal in "top up" and "top down" position) to signal the end of the cycle. This would allow for simplier electronics (not car dependent). But I may be wrong on this.
Now, if Porsche is using the SmartTOP in the 997s, the price might drop somewhat. Anybody knows about this?
Could be a bad microswitch on one of those. Either ohm out the switches one at a time or get someone with a PST2 to read out which zone is reporting open.
Latest update (Sept 27, 2004) now includes 987 and 997.
Thanks Scouser! :thumbup:
I don't think you could call it common but I know of at least two other cases of faulty (leaking) oil senders.Hi allI had a good long look to try and identify where my oil leak is coming from and one guess is that its coming from the oil sensor switch as on the cable there is quite much oil. This would suggest that the leak comes when the engine is running and then gets sprayed all over the place making it difficult to identify where the leak comes from. Is it common for oil to leak from the sensor ?
No gods here - just people helping people...
(for standard 996 not C4S)
Brake discs
Front: 318 mm
Rear: 299 mm
Effective brake discs
Front: 261.8 mm
Rear: 247.4 mm
Piston in brake caliper
Front: 2 x 40 + 2 x 36 mm
Rear: 2 x 30 + 2 x 28 mm
Brake pad area
Front: 254 cm
Rear: 196 cm
Total: 450 cm
955 701 105 00 G2X Support (prime coated) for ECE large plate
955 701 105 01 G2X Support (prime coated) for smaller RoW plate
You will most likely have to order this from Gert (Carnewal.com) or find a US dealer that can get it.
Yes, the lower shelf has a different curve in the faceplate since it sits lower in the console curve.Loren,Quick question...is the part number the same for the upper shelf & the lower shelf? If not, do you know the number for the lower?
I'm looking to replace the lower shelf on my '00 C2 Coupe.
Thanks in advance.
Lower Shelf - 996 552 243 01 01C satin black
or
996 552 982 01 xxx Shelf (replace xxx with appropriate leather color code)
or wood or carbon fiber
Leave the center console open... any open zone will cause a beep.
Those specs are for 996 brakes - Here is the same info on the GT3 brakes since they are about the same as TT/GT2:
Brake disc thickness, new -- front 34 mm, rear 28 mm
Minimum brake disc thickness after machining* -- front 32.6 mm, rear 26.6 mm (* The brake disc must only be reworked symmetrically, i.e. from both sides evenly.)
Brake disc wear limit -- front 32.0 mm, rear 26.0 mm
Peak-to-valley surface roughness of the brake disc after machining, max. -- 0.006 mm
Thickness tolerance of the brake discs, max. -- 0.02 mm
Lateral runout of the brake disc, max. -- 0.03 mm
Lateral runout of the wheel hub, max. -- 0.03 mm
Lateral runout of the brake disc when installed, max. -- 0.06 mm
I don't know the original thickness but the wear limits on 996 and GT3 is 0.6 mm.
In the SF Bay Area (a good shop) will run you about $800 - $1000 for the install and another $180 - $200 for a four wheel balance. YMMV...
1. No, when used with the proper wheel bolts (Porsche sells a kit) they are fully approved by Porsche.
2. A slightly wider track. You may notice a very slight improvement in low speed cornering - 5 mm is not very much.
For my 2 cents...
I'm not sure of the quality being a problem on the PSE. What I have seen is two or three PSE's delivered in a box that looked like it was run over by a truck. I don't think the shipping packaging done by Porsche is very good. If you compare it to say the Litronics that come double boxed and foam lined. Considering the cost they (or their vendor) really should package them better for shipping.
End of :soapbox:
Have a look at this thread
MY02 on C4S (cast iron brakes not PCCB)
Front -
Pads: 996 351 949 12 (1 set)
Damping Plate: 996 351 089 00 (4 needed)
Wear Sensors: 996 612 365 00 (as needed)
Mounting Parts Kit (bolt, spring clip): 996 351 959 11
Rear
Pads: 996 352 949 02 (1 set)
Damping Plate (28 mm): 964 352 096 01 (4 needed)
Damping Plate (30 mm): 964 352 096 00 (4 needed)
Mounting Parts Kit (bolt, spring clip): 996 352 959 11
Most of the oil leaks were fixed by the MY2000 builds. Some common locations (besides the RMS) are valve cover gaskets and cam sensors. You need to have a look at where the oil is dripping down at.hi its a year 2000 C2 tiptroniccheers
Most oil leaks can be repaired with the engine in the car. The most common exception being the RMS (Rear Main Seal). When repairing the RMS the transmission is removed and the engine is supported in place. What year and model car?
Ah, good thread. I am looking for the part # for the plastic holes (using the lingo from the thread). They were looking for the collar. Anyone have that part #.
Can you post a picture? Still not sure what part you mean.
To my knowledge - not without going to a racing fuel cell.
Anyone have a source for current supplements? My source has been unable to come up with any after 79. They keep telling me they can't get them from PCNA.
Karl
Sunset Imports in Oregon has all of mine except one (supp 87) we are waiting for.
2004 Boxster S Bumper Number Needed
in 986 Series Part Number Requests
986 505 311 06 G2X Lining (front bumper) (prime coated) for MY03- on Boxster S.
985 505 551 01 G2X Cover (around opening) prime coated MY03- on Boxster S.
The inside retaining frame is: 986 505 555 02 01C Retaining Frame (satin black) MY03- on Boxster S.
The parts list does not show a grill of a Boxster S - it looks open. There are grills on the side opening but only the cover lip on the center opening.
