37,313 -
Days Won
531
Posts posted by Loren
Not exactly what you are looking for... but nothing special here about a Porsche clutch.
1 - release lever; 2- release (or throw out) bearing; 6 - clutch disk (or driven plate); 8 - flywheel; 9 - splined drive for transmission (with needle bearing)
The Porsche mechanic who installed it, said the car handles very much like the new GT3, except for a "heavier" feel due to the extra weight of the C2.
You do realize that the GT3 weighs MORE than a C2 right? Your mechanic was wrong about that.
:lol: Maybe his mechanic is overweight? :lol:
On the Carrera, Porsche changed the spark plugs from 2 electrode to 4 electrode as of Nov 1998 builds. They continue to use the 4 electrode plugs but changed the heat range used. The current plug Porsche uses on all (Boxster/Carrrera) engines is Beru 14FGR 6KQU.
You likely need the spoiler wiring harness from the TT Aerokit (also a fixed wing). The part number is: 996 612 070 30 Wiring Harness.
This a simple harness that goes from the passenger side of the body (near the lid shock post) to the deck lid wiring.
The very early builds of the MY 99 cars were built in 1998. As in any first production run there were a number changes. Early build cars most obvious identifying characteristic is orange and red tail lights instead of clear and red (nothing wrong with these they just changed them).
If you are considering an early build car then ask the dealer to verify that it has had all of the Service Bulletin updates that it should have. The can easily do this by checking the VIN on the PCNA computer. And as with any I would suggest a CarFax on any vehicle you are ready to purchase.
Good Luck!
You've got mail...
When I got my Certificate of Authenticity in 2001 they were $35. I wonder whats warrants an almost 3X increase (greed?).
Order accepted (PCNA code: ACPORD) Your order has been accepted by PCNA.
Order amended. Some of you may see this in the status window. This code means that your order replaced an existing, stock order. This is done when possible, to speed the production of your Porsche. In other cases this reflects a change in the original order.
Manufacture date (PCNA code: MFGCNF) Your order has been assigned a production number by PCNA.
Planned production (PCNA code: PLPROD) Your order has been assigned for production by PAG. No additional changes to your order are possible at this stage.
Final production phase (PCNA code: PRDLST) This is the last checkpoint before your Porsche is considered completed.
Completed production (PCNA code: IMPINV) Your Porsche has completed production, has been invoiced and is ready for shipment.
Shipped from PAG (PCNA code: ONVESL) Your Porsche has been shipped from Germany, for arrival at port in about 20 days.
Arrived PDI (PCNA code: IMPPRT) Your Porsche has arrived at the Porsche PDI center (Pre Delivery Inspection).
Shipped from PDI (PCNA code: INVSHP) Your Porsche has been assigned to a transporter for delivery to your dealership in about 2 days.
Arrived at dealership (PCNA code: DLRARR) Your long wait is almost over. It will take us up to 48 hours to inspect, detail and arrange for you to pick up your new Porsche.
Hmm... my feeling has always been clean the rubber and use a dry talc compound. You don't want a grease or lubricant that is going to collect dirt and debris. Another trick I've heard is teflon tape. Applying it might be tough though. Then again, Porsche sells a lubricant for the rubber mating surfaces of the cab top to rear windows.
It is: 999 917 557 00 Krytox lubricant $33 retail :eek:
The oil pressure relief valve seal is: 996 107 123 50
The proper torque is 25 Nm. (19 ft-lbs).
Here is the fuel filter on a Boxster - similar location on a Carrera (but I don't have a pic). You will need to remove the plastic belly pan to get to it. Don't forget the ground wire.
...and gasoline will run down your arm. :o
First I want to apologize to those that have not been able to get access to Porsche Parts at Dealer Cost. There was a security foul up and some folks were told they did not have access to that page. That is now fixed and everyone should have access.
What is Porsche Parts at Dealer Cost?
Sunset Imports is a Porsche dealer in Oregon that is joining with RennTech.org to offer Porsche Parts at Dealer Cost (plus a small handling fee). They have some specials listed that include common maintenance kits, popular accessories and upgrades. These prices are excellent!
So, is this a banner type ad? - no, RennTech.org does not receive any of the small profit they make. This is a service that Sunset is gracious enough to extend to RennTech.org users as a place to get your Porsche parts - without paying an arm and a leg. Check them out and feel free to offer your comments publicly or privately.
I found some glove box info. I'll email it to you.
The dash trim pieces are covered in the DIY section. Search for dash trim.
Becker should have what you need as a prewired cable. You might want to check with Becker Australia. Here is a link to a Becker dealer in Australia: SoundLab Group
Here is the US information (for comparison).
We now have a Telephone power cable, 5001.524-276. This allows power/phone mute to the existing car wires without any cutting. The price is $5.00 (list).OEM Becker Radio removal keys, BNA-1184.989 ($1.76 set) Plus $5.00 small order handling fee
To add additional amplifiers use low-level audio adapter, 1185.640-276 ($16.60)..
Speaker/power plug is 1163.736-276 ( $14.00)
Phone mute/Aux audio-in/Tel audio-in/Removal keys in one kit is, 1319.116-276 ($16.40)
To order please call our parts department at (888) 423-3537 x1209
:lol: ...or you can download the Order Guides here at RennTech.org.
See the link at the top of every page... "MY04 Order Guides"
Speaker/power plug is Becker No. 163.736-276 about $14
Becker also sells a kit that includes: phone mute/Aux audio-in/Tel audio-in/Removal keys for $16.40 - Becker No. 1319.116-276
Becker (NA) is at: 888-423-3537 x1209
As a special feature for our Contributing Members we have added a new forum (under Other below) for Contributing Members only. Only Contributing Members can see and use this forum. Please continue to use the public forums for all technical issues.
222 is Traction Control (only available on MY99 C2's).
234? Are you sure it isn't 224 Limited Slip Differential?
TC and LSD were always sold together.
Sounds like an exhaust manifold leak to me or a compression leak. Not good... better find a shop that can check it out. I would not drive the car - just to be safe.
At this point I'm not sure I remember... last car I did (before the DIY) was a Turbo and I can't remember if it was different or not.
The larger one (30 mm) will only fit in one place so that should tell you for sure. Let me know what you find...
Porsche specs say - 18 MPG city and 26 MPG highway.
Sounds like you are right on spec.
If you look at my 3rd Radiator DIY (Loren's DIY pages link at the top of this page) I cover removing the front bumper. You will see that you likely will need to slightly loose all the front bumper screws... then move the bumper and tighten them down again.
Please list them here or try the list at: Kindel Option Decoder
Not to my knowledge - not on the 996.
There are however 3 different MAF sensors depending on:
C2 or C4 (MY01 and older) or 3.6 liter (beginning in MY02).
Unless you damaged one of the oxygen sensors (not likely) then I doubt this is related.
Have you had the gas cap or oil cap off recently? ...these are the two most common causes of a CEL.
Dash Rosette Attachment
Yes, it just snaps back in. If you had the defroster trim out also, then it needs to go in first. Also, make sure the defroster trim is aligned towards the doors so that it does not conflict with the alarm sensor cover.
