37,322 -
Days Won
533
Posts posted by Loren
44 minutes ago, rliberty said:
Hi All! I have a Becker CD-2 from a 1992 964 C4 and I have lost the code. Can anyone help?
Serial number: A0614401
Thank you!
Robert Liberty
502.533.4996
This is a radio not a CD player serial, right?
Not sure that's pretty old.
Try 7289
2 hours ago, TJ said:
Hello guys,
My radio is a CR-220 Becker 1
Type: 4362
Serial: y5021061
Build Date: 47/98
Thank you so much in advance!
Try 0298
3 hours ago, RyanCharlie said:
Thank you but 2109 didn’t work
any other thoughts?
Did you use the procedure in the Lost Radio Code FAQ?
If not, then your radio may have been repaired and the serial number changed (electronically.
If you did use the procedure and the code I gave you does not work then it is likely that the radio was repaired by someone other than Becker - in that case I can not help you.
1 hour ago, RyanCharlie said:
1998 Porsche Boxster
Bought car a year ago and haven’t been able to get the radio working since because of this radio code issue. We have tried 1209 based on what one service tech told us but it doesn’t work. Hoping you can help! Thanks!
becker
cr210
serial number: V5007001
Try 2109
Lost Radio Codes
DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS.
Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. -
4 hours ago, BadBilly83 said:
Hello Porsche friends,
I need the radio code for a 2001 Boxster I just bought for my son.
CDR 220
Type 4462
CDP 2081
24/99
serial 15076106
thanks,
Bill
Try 9397
3 hours ago, TNT79Bronco said:
Could use some help with my radio code.
Becker 1
Serial # 15001317
Type 4352
Thank you very much.
Try 7683
13 minutes ago, Julian Hibbert said:
Hi radio nor working after flat battery asking for code. Radio is CDR - 22
TYPE 4467
SERI 25008451
24/99
Any help much appreciated.
Try 7543
7 minutes ago, Martinanddee Clarke said:
Lost radio code, any help would be appreciated
986 Porsche Boxster s
Becker cassette radio model 4367 serial no x5018079
I already answered your request here...
1 hour ago, dangerdevon said:
Hi,
Just picked up a 2002 911.
Becker 1
type 4462
# 15007356
24/99
Thanks.
Try 9190
5 hours ago, Martinanddee Clarke said:
Hi Lost radio code, Wrong number in the manual can anyone help
"2000 Boxster S
Becker cassette Radio
Model 4367
Serial no X50 18079
Try 5217
42 minutes ago, Joe Forti said:
Hi Loren, lost code on my 986, infoo as follows:
CR 220
model 4362
SER Y5023640
Thanks!
Try 0465
4 hours ago, Tom951 said:
Hello, new 996 owner and the CDR220 needs a code, looked everywhere and the previous owner doesn't know where it went. Any assistance would be greatly appreciated, thank you
Model 4462
Serial X5033503
48/98
Tom
Try 4960
- 1
Best to scan for fault codes using a Porsche compliant scanner.
Or... the bracket that hold the solenoid is cracked. That happened on 996TT a few times.
P0021
Possible fault causes
- Dynamic driving style when oil level is near minimum (oil foaming)
- Solenoid hydraulic valve faulty
=> (e.g. mechanical fault or dirt in the oil circuit)
- Oil pressure too low
=> (e.g. due to oil dilution, oil thickening, wrong oil quality, fault in oil pressure control or oil pump)
- Intake camshaft adjuster faulty
- Camshaft stuck (incorrect or faulty installation) -
1 hour ago, Aa Rl said:
Loren can u help w/radio code : CDR220 4462
X5025800
thanks
Eddie
Try 9027
8 minutes ago, javier may said:
Loren can u help w/radio code : CR220 4462
Y5053014
thanks
javier
Try 8727
Bumper Plugs can do that...
Rear Center Console - 996/986
BUMPERPLUGS.COM
Custom paint-matched or contrasting console, finished in 19 stage factory chemistry to brighten up Porsche interior. -
You could try either Becker or Siemens repair centers.
57 minutes ago, m491drew said:
Didn’t seem to work - started flashing the first digit again after entering
Is that the serial number as displayed on the unit or the serial tag on the top or back?
The serial tag may not be correct if the unit has ever been repaired - even by Becker.
If a third party ever repaired they didn't reset serial number properly - if that is the case I can't help you.
1 hour ago, m491drew said:
Please help! Thanks in advance!
CDR-210
R-3297
W5024999
Try 5147
Porsche alarms were option on Boxster. M535 is the correct control unit.
The alarm horn should be down to the right of the battery and is just the horn. Sometimes it is hard to see.
Lost Radio Code - post your request here
in Lost Radio Codes
Try 1013
