37,322 -
Days Won
533
Posts posted by Loren
6 hours ago, Adrian32 said:
Lost radio code, please help.
CDR 220
BE 6625
ser# 25010524
01/02
EC 102
Thank you!
Try 1097
19 minutes ago, Vince DiPiazza said:
CDR-220
Becker 4462
Serial 25012898
Try 0631
2 hours ago, WaWaW21 said:
Hi, just hoping I could get some help with my radio code
Type - CRD-22
model - BE 6621
Serial - 15002210
Thank You!
Try 8468
11 hours ago, Globey said:
Hi,
Hoping to get some help with a radio code for my new to me 986 (great intro to the forum)
CDR-220 (44266
SN: X5033511
Thank you!
Try 5024
- 1
3 hours ago, Grapes La Roc said:
Hi!
I also can't find the Becker CDR-220 4-digit code after a fresh battery install into my 996. Can you help me please!
Type: 4462
Serial# X5026530
Gal: 00
48/98
Thank you!
Josh
Try 5210
3 hours ago, Guido Abreu said:
Hello, I have a porsche 996 2002 automatic Cabriolet with the IMMO M534 433Mhz. I have to buy a key fob transmitter but in the catalog there are several models, I want to know how to find exactly the part number I need.
Give your dealer/OPC your VIN and they can tell you which key fob can be programmed to your car.
30 minutes ago, Hayden said:
Hi - Hoping you can help me secure my radio code.
The radio unit model is a BE 1492. Serial Number is R1097931
Thank you
From the Lost Radio Code FAQ...
"Which radios fitted to Porsche can have their unlock code recovered through serial number?
- CR-220/CDR-220 - Becker
- CR-210/CDR-210 - Becker
- Traffic Pro NAV/CD - Becker" -
5 hours ago, b_986 said:
Hello,
Got a CDR-220, Serial No. #Y5052196 Type 4462. Much appreciated Loren!
Try 8356
- 1
1 hour ago, Jamie O said:
I have the same problem
Cdr-220
Type 4462
Ser# 15076680
2001
Try 0709
5 hours ago, Alfagt900 said:
Hi I have a Becker Mexico 7948 Serial code 85016005 . Any help with unlock code greatly appreciated, thanks!
CDR 220
BE 6625
ser# 15001866
27/01
EC 102
Thank you!
Try 0565
3 minutes ago, JAY_ROMEO said:
Hello,
Can you please assist me with the radio code for my Boxster?
My radio is
Type: 4362
01/99
SN: W5002449
Thank you in advance for your help.
Try 4718
11 hours ago, BobyYoo said:
Hi
I need 2 radios please
CDR-220Model: BE 4462Serial: 15088076
CR-220Model: BE 4362Serial: X5017527AppreciateThanksTry 5193
and
Try 1312
40 minutes ago, Jeeplife said:
Add me to the list of those needing helop with this! Thank you so much in advance!
Serial # W5018757
Model# BE2282
Try 1549
1 hour ago, CJordan said:
Will also check that. Spoiler behavior still puzzling. Is it functionally tied to ABS somehow?
Only to the extent that both signals go to the instrument cluster. Both are just warnings spoiler extended light or ABS activated light.
I would treat as separate issues.
13 minutes ago, israel said:
Lost radio code
SN: Y5051905
Try 0987
Sometimes you can get an ABS error from wheel slip - either from wet pavement or loose gravel. In those cases it usually clears itself.
Also, if your battery is 4 years old or older it should likely be replaced - a weak battery can cause all kinds if anomalies in these cars.
2 hours ago, gbm said:
Hello, We are hoping to get the radio code for this 2000 Boxster.
CR-220
Model: 4462
Serial: X5038003
Thank you!
Try 1025
1 hour ago, sluggo2 said:
Hello, in need of the radio code for my Boxster, seems the card that came with the car is no longer with the owners manual.
Becker CRD-220
Ser: Y5041728
Type: 4462
Thanks so much!
Try 3292
34 minutes ago, Tom ptr said:
Thank 😉
Have you got a web site or contact for the first code ?
No, the only place you can get a PCM codes is from a dealer/OPC.
2 hours ago, Tom ptr said:
Siemens
5WK 78003 - - E
PO8030205471/04
996.642.904.04 EFR
SI000406010209
BeckerIDIS
BE 2580
55150096
Please I need 2 code for Porsche 996
"These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM codes is from a dealer/OPC." -
Lost Radio Code - post your request here
in Lost Radio Codes
Try 8937
