JTT
JTT last won the day on April 13 2020
JTT had the most liked content!
About JTT
    Halifax, NS, Canada
    2003 Carrera 2 Cabriolet
  • Future cars
    Dream car - GT3
    Honda Ridgeline
2,179 profile views
JTT's Achievements
Community Answers
  1. Sorry for resurrection of such an old thread but has there ever been an answer to patent-guy’s question? I'm in the same situation. I’ve replaced the corrugated tube into the catch tray. Blown through it and it’s completely clear. If I pour water directly into the tray from the speaker hole, it runs out the valve at the front of the wheel well as it’s supposed to. However, if I pour water into the drain holes at roof, no water appears in the tray and water runs out the rocker panel in front of the rear wheel. I know the line (corrugated one) to the spigot on the chassis is 100% attached. How is the water not getting to the tray?
  2. I have been running B8s on H&R springs for a couple of years now. Stance is reasonable, not crazy low. Ride is firm and controlled but I wouldn’t call it harsh.
  3. I apologize for being late to the party. I am running PS2s in 295/30-18 on my C2 Cab, lowered on B8s and H&R springs. No clearance issues. That said, I wouldn’t do it again. The 295 on a 10” wheel is a bit too much. I noticed the extra sidewall flex almost immediately when pushing the car on corner entry (yes, mine are N spec). I’ll definitely go back to 285 on next change. If you have 11” wheels, 295s should be great. You may not notice, but this was my experience.
  4. Definitely redneck, but it worked a treat. Hope the pictures make sense. The tape was left stationary so you can see the support post is slightly offset to one side.
  5. Maybe it’s an optical illusion, but it looks like the length of the section before the seal is different between the two.
  6. JFP, as I remember, you can drop the engine down to crossmember level without disconnecting anything but the airbox? Anything you can think of that has to be disconnected before dropping it down?
  7. I'd second the spin on adaptor route. It eliminates the bypass, ensuring that 100% of oil is filtered.
  8. I got mine from Jason over at Warehouse 33. Drop him an email if you don't see them on the website, he often has access to items not listed on the site. Offers a discount to Rennlist members and likely RennTech too.
  9. I have a friend with PSS10s. It would seem that "adjustable height", is a bit limited. 10mm in front, 5 mm in rear, at least according to this information seemingly from the Bilstein manual PSS9/10 ride height limitations revisited - 6SpeedOnline - Porsche Forum and Luxury Car Resource WWW.6SPEEDONLINE.COM 996 Turbo / GT2 - PSS9/10 ride height limitations revisited - I've got a set of RUF PSS9s sitting at home in the box and I've been toying with the idea of putting them back on the car but wanted to make sure I set them at the correct height for optimum performance as designed. I've been doing some...
  10. You "may" need adjustable upper control arms or toe arms in the rear. Lowering adds in negative camber, some have issues, others don't seem too. I ended up adding both myself, as I was wearing inside edge of rear tires badly. Thought it was due to the excess camber (which definitely added to it), but rear toe settings I feel were mostly at fault. A little extra toe in at the rear seemed to make all the difference. Nice part about the link is they are all solid spherical bearing, so really tightened up the feel without any additional NVH.
  11. I replaced my 4 stalk with a 3 stalk and added my 4th stalk, so yes, it definitely can be done. You "might" be able to pull it off with the wheel still in place, but its tight working space. Not a big deal to remove the wheel, just make sure you disconnect the battery for a while before messing with the airbag and don't reconnect it until everything is buttoned up (or you'll get an airbag warning light that you need to clear).
  12. Another B8/H&R lowering springs happy customer here. deport pretty much summed it up. Slightly firmer, less body roll, but not at all harsh. Our roads suck too, and it's very good.
