Paul Gavazzi
Everything posted by Paul Gavazzi
  1. The A/C Blower in my 2000 996 C4 has stopped working. It started a month or so back by working intermittently. After starting the car the blower would come on after a minute or so. That went on for a couple of weeks and then it stopped altogether, I read everything I could find and did the following: Bench tested the blower -- ok replaced the resistor -- worked initially but failed quickly Checked the battery -- ok Read about the ignition issue -- started wiggling the key between position 0 and start. That got it going although not consistently. Replaced the ignition... still does not work. Put a meter on the fan connector and started the car... slight jump in voltage (like 1 vDC) Bench tested the blower motor again -- still good. I really don't know where to go from here. Any help will be greatly appreciated...
