Echapa13
Everything posted by Echapa13
  1. Long story short was fuel pumps, I replace 1 the car got better (it didn't die) but when you drive it, car won't accelerate replace the other pump and now everything good.
  2. In deed I replace the left pump now the car it doesn't dies, is much better but now when I'm driving it (now I can at least) it looses power and get like stuck, I'm replacing the right pump and crossing my fingers to finally fix the issue the whole forum is great and it has been a great Place to look for information
  3. I check the charging voltage and is 14v when the car goes to lower rpm the voltage goes to 12.5 or so. But I did separate fuel pump test and I have in one pump pressure unstable starts in 60 psi then goes as down as 20 psi (in that point is where the car whant's to stop and when the pump goes back to 60 psi the car goes to normal rpm yesterday I ordered today I'm going to replace it I let you know
  4. Will check tomorrow morning and let you know thanks
  5. I post you 2 videos for better understanding Any help or idea will be appreciated
  6. Hi I just bought a cayenne 3.2 V6 2006 base model, on my way home car was running fine, second day morning went to put some gas and after getting home car idle was rough Stop the engine and start back on now the car start goes to 1000 rpm for 5 seconds and then start shaking going to 500 rpm or less for about 30 seconds then car it self try to correct and goes to 1100 rpm for the same 5 seconds and then back to the bad idle. If i press de gas pedal right after the start car goes fine without any issue to 4000 rpm for the same 5 seconds and then complete loose the power, back to the 500 Or less rpm. When the car try's to correct back to the 1000rpm I can gas up to the 4000 rpm fine, is like a loop. I have a Autel Scaner shows 1 code in the getaway code 532 power supply what i have done: new battery new coils and spark plugs check fuel pump all good check the spark in the coils fix 2 vacuum pipes I have no idea of what else I live in Panama and I'm 600 miles away from the only Porsche dealer. I'm a mecanic but out of ideas now any help will be much appreciated thanks
