fitsintite
Everything posted by fitsintite
  1. Hi Boxsterfahrer, Thanks for the DIY great idea, I'm wondering if there is a way to verify this arm before removing it, I'm getting the same noises as if something is dancing around in the trunk. Thanks to all Frank
  2. Hi, I replaced the tubes and o-rings on my car 2 weeks ago and no you don't need to remove the plugs . Removing the tubes was a nightmare I had to brake the outside lip of the tubes to get to the o-ring and pull it out with long nose pliers and then the tube slides out easily, if you have to use the same procedure as me be careful not to let any parts of the plastic tube fall inside the engine . Good Luck
  3. Hi Kirk, you always deliver, Thanks :rolleyes: Nice clean setup :cheers:
  4. Hi Bristol, You forgot To show photos of your assistant :D Regarding the bar it does tighten the rear end and for the cost i didn't give it a second thought and made one ;)
  5. HI, Nice work keep us posted :clapping: Thanks
  6. Hi, Hope this helps. :welcome: http://986forum.com/forums/showthread.php?...ht=water+carpet http://986forum.com/forums/showthread.php?...highlight=water
  7. Didn't you just paint your car that Indiglow Blue :thumbup:
  8. Hi, I had the same problems and CEL always kept coming back on, so i replaced the MAF and so far 1000 miles and no CEL and just the improvement in throttle response was worth replacing it. :clapping:
