slope8888
Everything posted by slope8888
  1. Has anyone else had this problem? You crank the motor over to start it and it seems like there is a smal delay and its slower then most start ups...it has a new battery from Porsche from the previous owner...not sure if it needs a new battery of if its something else....any suggestions?
  2. I installed the Eibachs about 2 weeks ago, I also compared the springs side by side. The Eibach springs were a little taller themselves...I wouldn't worry about it. Install them let them settle for about a month then get an alignment with a full tank of gas. The stock springs have more resistance compared to the sports. The car will look nice once they are installed.
  3. Hello guys, I was just curious if anyone else has installed any type of Parrot bluetooth products in your guy's cars. I have a 99' 911 and I am trying to install the Parrot bluetooth but there are so **** many wires. Here is the diagram for it, I was just going to splice and tap into my existing wires since I dont have any wiring harnesses. There are wires like mute 1,2, and 3....wtf...I am lost...hahah any help would be greatly appreciated....Thanks!!! :D http://www.parrot.biz/documents/en/support...ot3200_3400.pdf
  4. its a 99...there is plus and minus but i put it down to minus and leave it there (off) still manages to be at the last temp with it being on when i start the car back up...
  5. Loren, the manual is displayed but still manages to still be on auto when i start the car everytime...is there any other options? thx
  6. Does anyone know how to keep this **** blower motor off. I guess the previous owner programmed it where it always turns on when you turn on the car...I just want to leave it off and when I want it on, I'll turn it on...also looking for an oil filter tool. Where can I find one? thanks!!
  7. Do you guys know if Pentosin coolant is ok to use on a 99' 996? Much cheaper then factory and I heard Pentosin makes it for Porsche..
  8. I was wondering how other 996 front seats are doing, I just recently picked up a 996 and the front seats look like they are starting to wear..I have grey leather. Do you guys recommend the dye? what are my options here? any suggestions? thx!!
  9. I was wondering if 997 mufflers will fit on 996 cars, and is there a way to modify them like the 996 mufflers?
  10. I know BMW and Volkswagon take blue coolant. Something special about it for the aluminum...I'm sure your ok though..
  11. wow..I dont know if I want to get into all that..I was just hoping some trimming and body work that the front oem turbo bumper will fit..thanks guys!!
  12. I was curious if anyone knew if a 01-03 911 front turbo bumper will fit on a 99' 911 carrera. Will it bolt right up or do I need the 911 turbo reinforcements..any feed back appreciated...thanks!!!
  13. Dan's precision alignments (Encinitas) is pretty good, he works on mercedes, bmw, porsche, and trucks...all he does is suspension and alignment work. He does local body shop repair issues as well. Tell him Doug from Brads referred you, his number is 760-753-0481
  14. Hello guys, I am new to the board and I am looking at a 99' carrera with 64k miles on the clock. It does need a clutch and prob a rms since someone will be in there. What does a clutch and rms normally run about? Say the car is in good condition, no aero kit...just a stock carrera. And..what if i just bought the car as-is...(needing clutch and rms), what is the value of the vehicle in that condition? Thanks for your guys' help!!
