mudman2
Everything posted by mudman2
  1. Many reports of this. Known issue, revised software was promised I dont know if its been delivered yet
  2. Hey Bill, if you look really really close you will see them no way would I do that without hhahaha agree with the rest Mike
  3. Switch to TIP, pull the stick to the left and manually select gears either on the wheel or the stick itself based on normal stick rules, do not select 6 Yes, they are LED lights. Are those an issue with the Cayenne. Also, can you expand on towing in manual mode?
  4. Yes, that also happens I have some now without no CEL (ugh)
  5. I Think this explains it better The MOSTHUR-997 allows full integration into the stock amplified sound system, allowing the end-user to replace their factory radio with an aftermarket navigation/DVD head unit while retaining the factory amplifier and speakers. Installing into the vehicle with just 4 connections and the included antenna adapter and M.O.S.T. fiber optic extension, the MOSTHUR-997 supplies accessory power, illumination, reverse, VSS (vehicle speed pulse), vehicle brake and parking brake to the aftermarket radio
  6. What kind of lights on the trailer LED ? if so just deal with the message if not further investigation required, fault codes will be present. The trailer system is the subject of many posts on all Cayenne boards. It works great, but is very sensitive to things it should not be, like light load. Dont forget to tow in manual and do not use 6th speed as it will put to much strain on the transmission
  7. Very good description of the coils going, there will be fault codes. If no tester replace all 8 and the plugs as they get damaged in the process.
  8. sorry but please read your manuals maybe it is new on 2009 or just Turbo models but my seats on the back would not fold flat. they turn only abot 80 degrees out of 90
  9. sunsetimports.com will have the best price for a new one or try ebay, I have seen them on there occasionally Yup i just got back from porsche and they told me that i need to replace my A/C control unit as some how absorbed moisture and is dead now! Can any let me know where can i find a new A/C control unit??
  10. Left is high pressure, right is low pressure. According to the book, you need to connect to BOTH. 9PA_GROUP_8_HVAC.pdf.pdf
  11. Fuse for aircon, see manual for fuse locations I had my AC control unit replaced twice but it was never dead
  12. I seem to remember its glued on and can be removed if carefull Watch out there are explosives behind it
  13. Ditto on that Yes, that is normal operation for an 04.
  14. There are many servo valves and a control unit, I would suspect the control unit, i had 3 on my 04S since new The actual valves are not pleasant to work on, why are you setting to 64 ?
  15. I have had Air Suspencion from new, the ride is so much superior from the steel sprung version I would not have one without it. Well worth every $ I even gave up on Bi-xenons to have it. As far as comparing with an X5 standard ride, I am not sure what you were driving but its far better (imho), much more controlled in all conditions especially at speed where the ability to hunker down is awesome
  16. Sounds like a sensor of PSM control unit, you need the error codes.
  17. The symptoms for this include CEL and Long Cranking times when starting after filling up. Part Required 948 110 202 01 (75 from dealer, 45 from Sunset) Some new Twist locks for the trim panels, since they have a mind of their own. You will need to remove the throttle design cover pull up it comes right off. then you will need to remove the 4 t 30 torx screws on the drivers side coil cover. then that cover will pull up although it is a pain, you can wiggle it out. Use a large flat blade screw driver or a penny to remove the 1/4 twist locks that hold down the drivers side engine compartment cover (the big black one) there should be 4 1/4 ttwists Then remove the rearblack panel, 1 1/4 twist in the center and 2 on the pass side of it. Remove the panel the purge valve is in the front of the engine between the head and the intake on the drivers side. It looks like a black cylinder little bit bigger then a film canister with a hose on one end to the front and the back is a hard black plastic line that runs along the intake and comes up in the back and goes to a rubber hose on the fire wall. Un plug the valve and push it off its bracket, undo the clamp with a pair of plairs and pull the hose off (sometimes you need gently grab the hose with the pliars and twist to loosen it up from the valve, you can damage the valve just not the hose). In the rear you will need to do the same, the rear hose never comes off easy I think they glue it on, use you pliers to crush the plastic line where the hose is over it. once it is crushed enough it will come off with needle nose pliers. Undo the injector electrical connections (wire clip on each) and pull them off, also free the ratcheting clip on the 1 inch flexy pipe crossing over the top. These 2 steps make removing the pipe a lot less violent. I did not and I would do the next time (hope not) I would cut the pipe after you have sprung it out of the gold clips along the intake, it make it easier to remove The pipe has some sleeving which is re-used, see when they are before you remove and put them back the same The hard part is the removal, putting it back is a piece of cake., Dont forget to hook a durametric to clear the code. I filled up for the first time this morning, perfect start afterwards. I need to give credit for this to a certain dealer tech from Miami (Firehawk) without whose help I would not have been brave enough to do this myself.
  18. P0441 Error Code The symptoms for this include CEL and Long Cranking times when starting after filling up. Part Required 948 110 202 01 (75 from dealer, 45 from Sunset) Some new Twist locks for the trim panels, since they have a mind of their own. You will need to remove the throttle design cover pull up it comes right off. then you will need to remove the 4 t 30 torx screws on the drivers side coil cover. then that cover will pull up although it is a pain, you can wiggle it out. Use a large flat blade scre Author mudman2 Category Cayenne (9PA, 9PA1) - Common Fixes and Repairs Submitted 08/10/2009 01:42 PM
  19. I dont think you can, you may need a new airbag unit
  20. I replaced the vent valve on the motor and reset the error codes, oil change next
