fbgh2o
Everything posted by fbgh2o
  1. I would not touch it for any amount of money. You could probably buy one in the US in decent shape and ship it to Lebanon for less than the price of fixing that one.
  2. I have been trying to figure this out all summer. The low speed fans come on at 100C and the high speed at 105C on some cars. I know of several people with early 996 who have reported these numbers and who can show factory manuals that indicate same. I can confirm that my fans are working fine and that the temperatures are confirmed via a Durametric at 100C and 105C. Also if you are using the climate control hack to monitor temperatures, it is off by as much as 3.5C. Mine shows as high as 103C when the Durametric shows 99.5C. I also know that there are posts here to the contrary. In fact, Loren has a different set of numbers; 98C and 102 IIRC, so I am quite confused. All that to say if your fans are working the way that you indicate, it seems like something is wrong....
  3. A couple questions Where is the noise coming from, front or rear of car? Is it a "whine" like noise that is proportional to road speed or engine speed? It could be as simple as a belt slipping under load.
  4. Thanks Loren... That helps me feel better about it - although the fan issue is odd.
  5. No, I did not. However, I would not have thought that a leak at the cap would require bleeding the system. The amount lost was maybe 125 to 250 ml - It was still above the min line on the tank. Moreover, I am 99% sure that the fan operated this way before as well.
  6. I had an expansion tank cap fail on me today, causing a leak - total amount lost was maybe 125 ml. I procured a new one, installed it and drove around. No apparent leaks. However, during the cruising around I used the climate control hack which showed 94C to 97C in traffic (as high as 100 stopped at a light) and 92 to 94 in clean air (ambient temperature 75F) and no evidence of the fans coming on at any speed. I checked when I got home and discovered that the low speed fans do not switch on until the climate control hack show 103C and my Durametric shows 100.5C (it appears that the climate control is 2.5C to 3C high across the range). This fan behaviour seems a bit strange as they are supposed to come on at 96.75C for the low speed. Any ideas? Many thanks
  7. Carbon Fiber Door Sill Repair I have had some cracking in the driver's side carbon fibre door sill that recently appeared to be spreading and the resin coating lifting. The following outlines an 80% fix (in my estimation) using fiberglass resin available at most auto parts stores (3M Bondo Fiberglass Resin). I have never worked with resin before and would rate this relatively easy to do, but I learned a bunch doing it and will share herein. Total cost ~ $20 Total time – 2.5 hours (+2 hours drying time for the Author fbgh2o Category Carrera (996) - Common Fixes and Repairs Submitted 06/12/2010 05:25 PM Updated 06/17/2010 04:09 PM
  8. I have had some cracking in the driver's side carbon fibre door sill that recently appeared to be spreading and the resin coating lifting. The following outlines an 80% fix (in my estimation) using fiberglass resin available at most auto parts stores (3M Bondo Fiberglass Resin). I have never worked with resin before and would rate this relatively easy to do, but I learned a bunch doing it and will share herein. Total cost ~ $20 Total time – 2.5 hours (+2 hours drying time for the resin) Tools Painter's tape Sharp utility knife Picks Sand paper grades (220 to 2000) Power drill and polishing wheel (or equivalent) Preparation First, I taped off the working area to minimize the potential for scratches. I removed all of the old cracking and lifting resin using a sharp knife and a couple picks to gently pry off the existing clears coat. Cut straight lines around the working area to limit the amount that breaks off. The resin coating has a tendency to lift, so delineating a working area by cutting into the existing good resin is critical. You need to cut all the way to the carbon fibre base. I should have done a better job of doing this everywhere. I would also suggest bevelling the edges to get a better adhesion and transition between the old and the new surfaces. I sanded the area around the area to be repaired with 220 grit to create better adhesion. I then cleaned the area with compressed air and wiped it with acetone. Repair Mix up the resin and apply liberally to the area with a paint brush. You need to fill a better part of 3/32" (2.5 mm). You will also need a rag to continuously remove the overflow of resin to keep it off the painted part of the sill. I had a great amount of difficulty getting the areas to fill near the curve of the sill (gravity was working well today). It took two applications of resin to achieve a reasonable result (but not great). On the second coat, I deliberately mixed more hardener and waited about 5 mins for it to thicken before I applied it. I also used a plastic putty knife to apply it, to get a better adhesion in the curve. This produced a reasonable result, but resulted in a rougher surface than I would have liked. Note: the tape is critical in keeping the runoff resin from sticking to the painted part of the sill. However, do not wait to long to remove the tape as the resin hardens it becomes difficult. I ended up waiting about 1 hour and had trouble. I used my knife to cut the resin at the edge of the sill, but it was a delicate and difficult operation. Next time I would test it after 30 mins. Let dry for 2 hours. Finishing Nothing hard here, just lots of wet sanding. I started with 220 grit to smooth the roughness and create a smooth transition between the old coating and the new resin (I actually used my Ryobi orbital sander to do this). Then by hand did the following (probably overkill): 320 grit 600 grit 800 grit 1000 grit 1500 grit 2000 grit I then polished with my electric drill using Meguiar's #2 Fine Cut Polish– 2 passes Meguiar's Plastic-X Polish – 2 passes. The outcome is acceptable in my opinion. There is a bit of bubbling under the old resin which shows up in the pictures and the area under the rubber weather stripping is a bit dull in sheen and less smooth, but otherwise I feel better off that when I started. The flash actually makes the repair looks poorer than it is to the naked eye. Next, I will repair the two cracks in front of the area that I just repaired.
  9. AutoImport on Woodward. Ask for Jason. They do much of the work on my C4.
  10. After having tried everything else, it appears that the issue was the gauge in the cluster. I bought a used and installed it today. At start-up, the needle went straight to 5 bar (and the oil was probably still a bit warm). I am going to guess that the PO, when he changed the gauge faces, damaged something in the gauge and did not properly index it when reassembling. I come out really ahead on this as the new cluster was a Canadian one, so now everything is in the correct units as well.
  11. Interesting, mine is hard to shift into second when cold. It requires a very deliberate hand and much slower shift than normal (until it's up to temperature). I know it is not the synchro as its was replaced less than three months ago when the gearbox was rebuilt. The gearbox oil is the Shell type specified by the factory. Therefore, in addition to the synchro and lubircant issues there must be a third one - I am guessing shifter mechanism adjustment... Any thoughts?
  12. . Tested tonight... and got full sweep in the gauge. I guess it is time to test using an analog gauge to see if the gauge is miscalibrated.
  13. Excellent video... I just did mine in under 2 hours (most of which was spend actually cleaning the radiators).
  14. So, assuming $125/hr at the dealer... 20 hrs... Seems a bit high.
  15. I am looking a buying a set of used Recaro Sport Topline seats. Seat . I currently have Comfort Seats with memory (therefore they are all electric). According to Recaro's base frame fitment guide, the Sport Topline seats will fit in a 996, but must have electric backrest adjustment. The Recaro seats that I am looking at are all manual. Given this, can anyone tell me if the manual seats really won't fit and if so why? Thanks
  16. Problem resolved. Had the transmission rebuilt. The pinion bearing was failing and the spider gears were badly pitted. It also needed new synchro rings in 1st and 2nd. Main shaft bearing was fine. There was no evidence of debris in the transmission and my mechanic indicated that the suspected a manufacturing defect in the gear not being hardened properly (he is a factory trained Cup car mechanic - so I believe him). Cost was much less expensive than a rebuilt replacement transmission (due to my being in Canada and the associated cross border costs).
  17. Thanks for the picture Loren. Quick question, is it accessible from the rear or does that need to go up on a lift?
  18. Shifter Trim Refinishing The finish on the U-shaped silver trim that surrounds the shifter boot on the 996 (1994 C4 I my case) can start to bubble and lift, as you can see from the pictures. While I had read that it would require a full replacement the boot assembly (over $250) as the trim is an integral part of the boot assembly, I decided to try to remove and repair it. Trim removal from shift boot assembly It is possible to separate the trim from the assembly. Six plastic studs are molded into the back side o Author fbgh2o Category Carrera (996) - Common Fixes and Repairs Submitted 01/09/2010 06:23 PM
  19. The finish on the U-shaped silver trim that surrounds the shifter boot on the 996 (1994 C4 I my case) can start to bubble and lift, as you can see from the pictures. While I had read that it would require a full replacement the boot assembly (over $250) as the trim is an integral part of the boot assembly, I decided to try to remove and repair it. Trim removal from shift boot assembly It is possible to separate the trim from the assembly. Six plastic studs are molded into the back side of the trim to hold it in place in the boot assembly. Starting at the open end of the “U”, I pushed from the backside and lower part of the trim. It took some time to work them free and separate it. Go slowly, be firm, but gentle. Removal of old trim finish The trim is a piece of U-shaped plastic covered in a foil-like silver finish. It is this finish that was bubbling. Starting where it had bubbled up, I used a sharp knife to peel the old foil off. This can be time consuming because the foil adheres quite well where it is not bubbled. Using a sharp blade (razor or x-acto) flush against the surface allows you to peel back the foil enough to use your thumb and forefinger and pull it off in small to medium-sized strips. I also found that if you do this at the edges of the tri, you could get larger edge to peel off. You want to be careful not to gauge the surface as this will likely show through when you paint it. I removed 100% of the foil from the visible portion of the pieces, all of the edges, but could not get about 15% to 20% of the foil on the inner (concave) portion of the trim piece to come off and did not think it was necessary to spend any more time. Refinishing Preparation - Very lightly sand the outer surface of the piece with 220 grit (I did not have any 360 or 400) to rough up the surface and smooth any knife marks. Wipe it down with a damp rag to remove the sanding dust and then wipe with a rag dabbed in a small amount of acetone to clean the surface. Prime with Dupli-Color grey primer – 3 light coats. Finishing – Finish with 3 coats of Dupli-Color VW Diamond Silver (P/N 8802029) and 2 coats of clear coat. (I took the trim to the store and VW Silver was the closest match). Reinstallation The trim piece simply snaps back into place. Conclusion The silver is a pretty close match (the picture is not representative). The new finish lacks, perhaps, a bit of metallic lustre, but is much better than what was there. Total time was about 1.5 hours, but it took about 8 hours with paint drying time.
  20. I am going to guess that this is correct, because: The PO did do a gauge face swap at some point. The needle parks at about -0.8 bar below 0 off and moves to -0.4 bar when the ignition is on but the car is not running. Thanks for all the help!
  21. Thanks. Will try that. It seems that the PO changed the gauge face plates... I wonder if that does not account for some of the issue.
  22. At 2500 RPM cold, it reads about 4.2 maybe 4.3 bar It reads about -0.4 bar (i.e. below 0) engine off and key on.
  23. Changed the oil pressure sender with little if any impact... No sure where to look next.
  24. You have your priorities right... All the best to you and your family! I wish there were more people like you.
  25. Update - appears to be the bearing on the shaft that carries gears 4, 5 and 6 and may also be the pinion bearing...
