trauh
Everything posted by trauh
  1. You must have a switch with an LED in it. The wiring is different for that, and I have never been able to figure out how to make it work for a garage door application that uses its own power for the transmitter. I believe that the middle pin is used for a common 12V feed, and that the twin middle pins are for the toggle switch, with the outside pins for lights and led power. I had to use the middle pins for the opener switch, and could not figure out how to get the switch to back light. I tried jumping the outside pins from my PSM (which seem to have 8 volts across them with lights on and car off) to the outside pins on my switch, but no luck. Please let me know if you figure it out. Otherwise I might have to get the targa switch...
  2. I have a 2001 C2 Cab with 16K miles on. The check engine light went on around 7 weeks back with a P1128 code (cylinders 1-3 too rich). It since been reset and reoccurred three more times. So far I've followed Loren's advice and checked for an obvious exhaust or intake leak and have come up empty. We did find a the air intake on the throttle body to be a wee bit loose. After all that it has reoccurred again. Here is the situation. I always occurs on the highway in heavy traffic, when the car has been moving slowly (10-25 mph) for a few minutes. Its been top down every time (I know, shouldn't matter, but hey, I'm covering everything). Outside temp has ranged from upper 70's to upper 90s. It does not seem to repeat every time the car is under these conditions. But it has only occurred moving slowly on the highway. I'm thinking of trying some fuel injector cleaner tomorrow, any maybe pulling the fuel filter (though that doesn't seem likely to me given the mileage and slow speed circumstance). Any thoughts?
  3. The check engine light turned on when I was driving on the highway yesterday (2001 C2 Cab, 16K miles, one week after installing PSE exhaust). Stopped by my mechanic and he pulled one code out - P1128, which translates to "Oxygen Sensing Adaptation Area 2 (Cylinders 1 - 3) - Rich Threshold". My mechanic reset the light and sent me on my way to see if it recurs. Any one have any experience with this (or suggestions)?
  4. My local mechanic did it in just a tad over 2 hours. Man does it sound awesome. I'm thinking about ripping out the stereo so passengers don't ask me to turn some music on...
  5. That is "sound" advice! Someone backed into my 996 when I had the horns blaring, and I immediately ran out and got the Griots horn. There is no chance that someone will not notice me the next time.
  6. I installed a garage door opener in my 2001 C2 Cab by taking a handheld opener and soldering wires to the switch contacts. Then I purchased a switch for one of the blank slots to the left of the radio and connected the wires to that. I am trying to figure out how to illuminate the switch, but since one of the leads to illuminate the switch is already in use to complete the circuit for the garage door opener (which has its own power), I am not sure that i can safely do it. Has anyone else ever figured this out?
  7. I think that is exactly what my problem was. Good luck.
  8. All fixed. With continued observation I noticed that the alarm system led did sometimes cycle into the double flash indicating a fault. Yesterday I picked up the new alarm horn and 5 minutes later it was installed. So far it works like a charm. Horn beeps, and the system arms correctly (which I now believe it never was doing). Crossing my fingers that it stays that way. Loren and Toolpants and others, thanks so much for the guidance. This board rocks!
  9. OK, now that I've read the instructions (and came to grips with an airbag sitting in there), I am going to let the dealer track this one down... Thanks again Loren.
  10. Uh <insert embarassed grin>, no. Just in the TSB section. Thank you.
  11. I finally tracked down a rattle to the drivers door panel. If I bang on the door with my hand, I can hear a rattle inside. Anyone have directions for removing the door panel trim? 2001 991 C2 Cab
  12. Interesting - I called my local dealer and they report the part as 996 637 117 02 (or is that 07). 2001 996 C2 Cab. Any idea what part they identified it as?
  13. That is a huge help - I am off to buy a new alarm horn. Then I'll have to tackle the false alarms... Might be time to get PSE put in while I get the alarm diagnosed!
  14. 2001 996 C2 Cab, need a new alarm horn. Also, any suggestion about a good mail order dealer?
  15. It is never at 0. It is at 9.6 with alarm not set/triggered, and when alarm goes off it bounces up around 11.
  16. Just tested the alarm horn voltage, and it goes from 9.6 volts up to 11 volts or so. That doesn't sound like good news - dare I guess that I look to the alarm control unit next? Re: the other horns, I replaced the Porsche horns with the Griot European horns. They are way louder.
  17. Sorry, bad explanation on my part. The alarm horn is dead but the alarm light just normal flashes when I turn the alarm on. I double checked that it does activiate properly, and alse verified that if I leave a zone open that it is detected. I am assuming that when I come back to the car and find the flashers going that the alarm has been set off, so I will need to track down why it is going off randomly.
  18. Yep - just checked and the alarm horn is dead. So I guess I will have to check voltage to verify it is the horn (as per your suggestion). Then its off to the local repair shop to pull the error. Thanks for all the help.
  19. One more question - I noticed that when I press my key remote, the red LED flashes fairly quickly (maybe 4 times per second or so) - is that the proper behavior?
  20. Loren - what I intiially reported was about the cars hazard lights flashing. I did not pay attention to the alarm system LED at all. Now I will start watching that (I'm sure that observers will think I am just lusting after my vehicle...).
  21. Interesting. I will try locking with the key. I did recently change the battery in the key remote. Are the flashing blinkers used to indicate the alarm was triggered or a fault? I just read about watching the red alarm indicator, so I'll have to see if that starts double flashing the next time.
  22. 2001 996 C2 Cab. When I activate the alarm I frequently come back and find the blinkers (hazard flashers, turn signals, you know what I mean) flashing. Alarm siren never sounds (not that I have ever heard). When I unlock the car the flashers stop. This has happened both top up and top down, and only when I activate the alarm. Alarm seems to activate correctly (no beep warning). And it seems to be a new problem this season. No changes to the car, other than replacing the horns late last year (and the horns seem to work fine). Any thoughts on what might be wrong?
  23. My 2001 996 had the hardtop on it (with the improved hardtop latches, per Porsche). When I went to remove it last night, I had a very hard time getting the top off. I opened the doors, lowered the rear quarter windows, fully unlatched the front catch, and then opened the latches in back (yes, all the way to the stop). It was a real struggle to get the back to release; with the latches open I had maybe a quarter or half inch of vertical play, but could not lift the top any higher in back than that. After 20 minutes of opening and closing the latches I finally popped the front out of the tabs and then muscled the back out. Did I do something wrong (like not lowering the front windows even though the doors were open), do I need to adjust the latches, or do I just need to apply more force?
  24. Thank you both for the responses. You are exactly correct. I followed directions the first time and plugged into the cigarette lighter, then the wall outlet. The second time I didn't. Who would have thought it mattered. Next time I will follow directions. Used the snowblower this morning (Boston). Its going to be a long 3 months waiting to get my C2 back on the road. I wonder if they make PSE for an Ariens...
  25. I use the Porsche brand battery maintainer on my 996 for the winter. I recently noticed that the red light on the unit that plugs into an outlet is on all the time. I think that it used to go out, only staying lit when the charging circuit is in use. That makes me wonder if I have a drain now that I did not used to have. Can someone else with the battery maintainer let me know whether or not the light really does go out? Not sure if this is related, but I noticed that the red light on my radio flashes on and off (single flash). I was thinking it only does that when the car is locked (the car is unlocked). Am I wrong about that?
