Stefan
Everything posted by Stefan
  1. If you are really 1.8 hm then you are too tall for the Boxster :) I am over 2 m tall and I have no problems with the clutch. One thing that helps is to put the seat all of the way down (can be done with both power seats and manual seats). Adjusting the height of the seat changes the distance from the pedals in a way different from front-to-back adjustment. I added lumbar support to my seats by pulling out the seat insert and shoving some foam in there. It took only about 5 minutes and helps a lot.
  2. I assume you're referring to a headliner for the convertible top (not the hard top). GAHH sells them. For some reason, they only work in 2000+ (which is fine for you but not for my 1999). If you find out why they don't work in a 1999, please let me know. Link to product page: http://www.gahh.com/boxster-roadster-2000-...7_341_3005.html
  3. I had the same problem. I put a piece of tape on the switch (not to hold it into a fixed position but to make it so that the convertible top pushes the switch slightly farther) and that completely solved the problem. It took about 30 seconds and cost nothing.
  4. It does not mean that your airbag is non-functional. It means that there was/is a problem somewhere in the airbag system. The problem usualy results from a grounding failure on the seat belt. You will need to have the light reset by the dealer, although it may be possible to fix the problem itself (and leave the light on) without the dealer.
  5. Try this: Alan Gun leather. Supposedly very high quality although I have no personal experience. http://www.aglausa.com/p/home.html
  6. When you say "recommended by Porsche" can you expand on this? 5 mm for all four wheels? And is this a cosmetic change they are recommending or a performance change?
  7. I think that a leather expert would be able to tell you if they can do it. In general, I think they have "ways" to recondition even worn leather. It's worth asking.
  8. On froogle.google.com, type "plexus plastic cleaner"
  9. I would think that bringing the seats in to a shop that does leather reconditioning would be much cheaper.
  10. Even if you bleed the clutch it still takes less than 1 liter.
  11. I meant "set the seat and mirror positions"
  12. On my 1999 Boxster I set the set and mirror positions then press and hold the memory button. While I am holding the memory button I press one of the numbered buttons. Then in order to put the seat into the memory position, I have to push and hold down the numbered button until the seat is in position. Is that what you're doing?
  13. I believe there is also a process whereby you put in some sort of liquid metal then rethread but I'm not familiar with that process. I believe that you can find new calipers for under $300 online.
  14. Cap 2 has a much cleaner look. The extra circle in the first one is distracting.
  15. Good question because I want that one and I haven't found the part number for the glossy one (if it exists).
  16. The control box adds a feature that moves the low beams up to fill in the high beans. It is a really nice feature and I recommend it. I'm think that you have to have the wiring (but not the control unit). The wiring comes with all kits unless they are stolen. Auto-levelling keeps the headlights on the road even when you go over a bump. It is only available for factory-installed litronics.
  17. Whether or not you need a spring compressor depends on whether the spring is compressed by the strut or by some other part on the car. From the picture it's hard to tell but the stock setup does not require a spring compressor.
  18. Most resistors are coded with color stripes that tell you the intended resistance. Take a look at the existing ones to find out what they are supposed to be.
  19. Thanks. I've seen that. Unfortunately it doesn't include many of them.
  20. Oh, and part numbers for both the blank switch (no label but functions as a switch) and the blank switch with a light.
  21. I am contemplating various electronics hacks to my 1999 Boxster and I think it's pretty cool to use switches that are pre-labelled. For example, the targa roof switch looks a lot like a garage door (perfect for a garage door opener hack). Does anyone know where I can get a list of different available switches, including part numbers, pictures, and whether or not they are available with the glossy finish? Additionally, I understand that the switches are availble blank. Does anyone know what technique would be recommended for custom painting my own label? I have a steady hand and a lot of patience so I wouldn't mind trying.
  22. Look into powder coating them. Also, there is a new process similar to powder coating that is supposedly more resistant to scratching and which looks amazing. (Sorry I don't remember the name of the process)
