lmurthwaite
Everything posted by lmurthwaite
  1. Hi all, I have been a victim of this issue too. It maybe just me, but my car seems worse if I have given it a bit of a heavy right foot and I am in manual mode on my Tip. The last time it happened to me was after a good fast drive. The car was warmed up enough. I pulled into a petrol station and the noise was awful. I was convinced I had broken a big end bearing or piston ring. The noise, as with all others seems to come from the right bank behind the muffler. When I listen in from the top of the engine (through the hood) I cannot really hear the noise as much. I had my Oil Separator replaced last year and it does seem to be worse since then. I believe the car was replenished with 5W40 Mobil 1. I am thinking of doing an oil and filter change with 0W40 to see if that makes a difference. It does make me nervous about putting my foot down. I have a 1998 3.4 C2 tip (some say Carrera S, but I don't have any evidence of the S anywhere on the car). Has there been any further investigation done by anyone on the site? What could happen to the engine if I used 15W40 instead of 0W40, what do the numbers actually mean? Does 0W40 begin thinner and remain as thin when it heats up where 15W40 is thicker when cold and gets thinner when hot?
  2. Hi all, I have noticed recently that my gear selector gets stuck in P. I have to pump the brake pedal in order for me to be able to get the car out of park on some occasions. Sometimes worse than others. Does anyone have any experience of this and what can be done to rectify it? Thanks, Lee
  3. yes, they still work but barely move. 1 inchat the most and they slap back to the resting position after each wipe.
  4. Went to my car this morning to dig it out of the ice. I switched on the engine and let the car warm up. After my screen was clear I went to use the wipers. They barely moved. Then I realised that they were actually switched on. So when I started up the car the wipers would have tried to wipe but they were frozen to the windscreen. Does anyone know if this is repairable? The motor is working as it tries to move the wipers but something must have come off or disconnected on the mechanism. Was very surprised that a little bit of ice can break the wipers.
  5. I have the same problem too. Going to look at the weekend. Is the sensor accesible from the top or through the arch liner?
  6. Was there any outcome to this? I have exactly the same symptoms with the knocking engine on occasion.
  7. Togilvie, that's good to know.... I have a ticking and we believe it to be something lose on the exhaust manifold a bolt or so... that ticks with each exhaust pulse... were hoping its that... otherwise were looking at a bad lifter? it ticks faster as rpm increases.... its going to the shop this weekend so I'll let you guys know what we found.... I'm very interested to hear what the result of your garage vist was. I have the same problem. An intermittent ticking noise that sounds like a knocking camshaft or tappet. It happenes usually after I have given the car a bit of a spank on the motorways and it tends to happen to either side of the engine just behind the rear wheels. I'm certain it's a lifter or some sort of oil starvation. I have a 98 C2 Tip 3.4l.
  8. If the sound actually comes from the steering wheel cowling itself then it is the indicator return pin. This is the piece of the indicator stalk that makes a connection with the steering wheel upon return to centre thus disabling the indicator turn signal. I have the same thing, it sounds like a ratchet. Haven't fixed it yet as can't be bothered but you can lubricate the baulk that it makes contact with to stop the noise.
  9. VarioCam Plus is quite different As a Contributing Member you can read the 4 page write up in the MY2002 Technical Information Book. Looks like I might have something a bit deeper going wrong. Sat listening to the car tick over last night and it started knocking for no reason and then stopped again after a while. Think there maybe some open heart surgery required in the new year. Oh woe is me. I have the same sound you have... coming out of the right rear of my car.... took it to porsche... scored cylinder #6... the explanation from a tech is probably the bearings are worn out and it causes the knocking at low rpm.... when I rev my engine past 4000 rpm the knocking disappears... does your knocking disappear over 4000 rpm? I can't say for sure what your issue is but are you burning a lot of oil as well? Not burning any oil I and the knoking seems to disappear whenever it wants to no matter what rev range I use. It can run fine, start knocking from either the left or right bank and then stop after I switch the engine off and restart or it will just stop on it's own. It drives well too, even when it is knocking. It needs to be garaged I think I just need to get a ballpark on what it could be as the last place I took it to said is what normal. I don't buy that though. Nothing that knocks is normal as something is wearing out due to it !
  10. Noticed this post from a couple of years back. I went from Maserati to Porsche because I was fed up with paying for road tax and insurance for a car that was always in the shop. I hope this info isn't 2 years too late !
  11. VarioCam Plus is quite different As a Contributing Member you can read the 4 page write up in the MY2002 Technical Information Book. Looks like I might have something a bit deeper going wrong. Sat listening to the car tick over last night and it started knocking for no reason and then stopped again after a while. Think there maybe some open heart surgery required in the new year. Oh woe is me.
  12. And do I have it? I have a 1998 3.4 C2 tip. I have posted about this before but on closer inspection have found that when I give my car a hard drive the engine knocks from what appears to be the cam end of either side of the engine. At first I thought it was just the left bank but I heard it pretty clear from the right after a particularly stressful drive home from work which resulted in a heavy right foot. It's only after sustained hard driving that it appears and after a while it settles down and becomes quiet again when driving normally or left switched off for a bit. The drive home from work is just the A2 so no lateral forces come into play with twisty roads or anything. It's definitely a metallic sound like a badly adjusted tappet or worn cam but as the noise disappears after it's calmed down it can't be anything that is permanently worn or damaged. Becoming increasingly concerned but would like suggestions so that I am armed with some info before I garage the car. Any ideas?
  13. Hi all, Wonder if anyone can help me. I have a 1998 996 C2 with standard headlamps. The drivers side dipped beam no longer works although the side light, main beam and foglamp do work. I have changed the bulb and even swapped the working bulb from the passenger side into the drivers side in case I bought a dud. Still no joy. I swapped fuses 9 and 10 around in case it was the fuse but still no joy. As it is just the dipped beam I am stumped. Are there any relays for either side headlamp as I cannot for the life of me think what else it could be. I can't see it being the switch as the other lights on the drivers side work. Any help appreciated as I'm often mistaken for a motorbike when dodging through London traffic now ! Have also removed and refitted the headlamp a dozen times in case it was a bad contact. Scratching my head profusely now. Thanks, Lee
  14. Hi all, Whenever I put my foot down to give my car a good pasting I end up with a very noisey engine when I stop. There is a loud ticking from the left bank somewhere. If I proceed to drive normally for a while or turn the engine off for a few minutes it goes back to normal. It sounds like a knocking cam or tappet type of noise but it can't be either as the noise goes away once I treat her nice again. Are the 3.4 engines partial to oil starvation anywhere? I have recently had the oil separator replaced, an engine flush and new oil/filter installed which hasn't remedied the situation. Are the lifters a common problem? If so, how difficult are they to replace? I'm nervous about putting my foot down now which is embarrassing when other oiks want to try it on at the lights !
  15. Doug, I am awe inspired by the way you have done this job. I have recently aquired the need to fix my own oil separator and I'm keen to find out how to do it. I have a 1998 911 996 Tip and I am getting all sorts of reports that the engine needs to come out and other horror story. I am quite mechanically minded so if I could see what to do and what to look for I would do it myself. Did you ever get to writing it up or having any pictures of what you did? If so, I would be forever grateful to be able to see such infomartion. Kind regards, Lee.
