txhokie4life
Everything posted by txhokie4life
  1. If you see me running around with a bunch of 9v batteries in OBDII bundles just before race grid -- LOL
  2. The rain, the battery running down, battery cables, kill switches, fuses, relays, DME, Immobilizer, Key RFID, etc None of that had anything to do with it Shortly after I bought the car I installed a traqmate system, including a traqmate USB to control the cameras and data acquisition. That system had been in the car for nearly a year prior including 2 or 3 event weekends with no symptoms whatsoever. There was a pin on the traqmate usb labeled 5v with the input analog pins. The documentation. Is poor, so I hooked up 5v off the obdii port after having found you can get 5v off of there (I don't remember how that was determined, probably internet) I eventually had to buy a street car to have a known good reference. She showed up late last week and was keen to success. After checking things back and forth between the street car and the Spec Boxster, including triple checking the DME. I decided some input to the DME must be wrong and is causing the DME not to let the car start. So I wrote out all 88 pins and made a chart and one by one probed each signal in the street car, and then did the same in the spec boxster. After probing all the signals between the street car and spb I noticed only a couple differences, one was the software voltage pin which only connects to the obdii port. Street car was 0v, spb 5v. Also the durametric could talk to both dmes, but on the spb, all live data was defaults and voltage was 0v, regardless of the DME, while on the street car with both DMEs I got live data. I went home and thought about where the 5v could have come from, and I remembered the traqmate usb had a 5v pin. I also remember sourcing that 5v from the OBDII connector as that is what I had found online to do. My spidy senses were tingling -- was I on to something? About midnight last night, I found some documentation online on the old traqmate system. It wasn't very good, but I could see a photo of the pins labeled on the USB box and blew up the picture. , It wasn't clear, but it looked like 5v was an output Not an input!!! I had figured at the time that the 5v was needed for the analog data acquisition, not the other way around. Surely it couldn't be that simple. After a sleepless night I ran out to the shop this morning, unconnected the traqmate usb And she fired right up Motherf@cker!!! I think the 5v put the dme into some sort of program mode or something, disabling its ability to start the car. Why did jumping it work without battery? I think once you got 14v, the 5v wasn't high enough to put it in the program mode... I also think that once you get running, the DME just does its thing -- OR, the Boxster's alternator put out 14v, and once again the 5v input was read as a low, not an assert. Further complicating the matter was the small fuse box that was added for accessories that I had tapped off of for the traqmate 12v hookup is janky, and I don't think it has a good internal connection. That's getting yanked and a new, and more accessible unit will be installed. Just diabolical.... Now I have to put it all back together and get my medical done and sign up for NOLA. Thank you very much to all who supported my efforts and responded to my posts -- especially Ahsai. If nothing else, the moral support allowed me to just keep plodding along.
  3. Yes grid E188 exists in MY2000, but contextually it doesn't make sense, it's the pin 86 on same relay Re/Bl, not the pin 30 Yellow -- So I don't think that is it. Ironically there is an E188 connection as well, but it is the wrong wire to the same Relay (Re/Bl pin 86). Additionally, the page 19 schematic is wrong -- as it shows K48 connecting a Re/Bl wire to Start Lock, which is actually K158. (looks like the connections are transposed) On the MY99, in context -- the signal doesn't have the a split connection on the pin 50, Yellow wire seen on 1999 to E188. I'm wondering if that is also a schematics error on MY1999. Mike
  4. S did get the 7.2 for 2000/2001. What page is E188 on for the other cars (I suspect it's similar) thanks, Mike
  5. Power Supply/Fuses K155 Sheet 16
  6. Hooked up my durametruc can access both dmes On their respective cars. on race car all my live data looks like defaults and voltage is 0v on the street car I get real values and 12v for voltage. i was short on time and didn’t think to swap DMEs, will do that next time plan to probe each dme pin values as well might not be able to see cps on street car because I’d have to hack up ability to run starter without dme (which I don’t think can happen without mods)... will add it to the list of possibles.
  7. I have most of the wiring diagram understood. However, I'm confused about how to interpret BOX E188 Normally I would read that as ROW 188, Column E on an electrical diagram. But for a 99 Boxster there are only 170 Rows. thanks, Mike
  8. Cut the Crash wire on the running car 12v one side, 240mv other car started... so so that has no affect !!! the search continues
  9. Luted as EXP Cutoff, DME pin 12. I'm probing X3/1 - pin 6, GN/OR goes to M126 CU Airbag Which either goes to module M562 Control Unit Airbag pin 24 Crash Output or M563 Control Unit M R S pin 34 Crash Output It suggests this is coming from the immobilizer? I'll need to double check if mine is plugged in on the race car at this moment. (In theory its not needed because I have had the DME re-coded not to need the immobilizer.) I'm at the house now -- headed to shop later. However, that said, I had the set sent off and confirmed it would start another car before the modification (and after the no-start issues). I'm not at the point of hacking the good cars wiring harness yet to disconnect this signal to see what happens (but I'm getting close ? Mike
  10. Finally got the street car. fires up nicely drop in my hacked dme and it fires up just as quick. started probing some signals that seem key. theres one listed as crash its 2v on good car, 12v on race car. if I short the race car to gnd via probe light with multimeter in parallel it drops to 0v, but won’t start. set to 2v using variable supply, won’t start 2v is odd value, wondering if that signal is some sort of digital waveform where the ECU is a weak 12v pullup will grab scope tomorrow
  11. Any idea what the 88 pin adapter for the OTC is? I can find the basic box on eBay easy enough, thanks, Mike
  12. Just bought a street car to map DME and other signals in running car so that I'll have a check and compare list. I know a bit crazy -- but at some point, what is there to do. Not having a reference was burning a lot of time and angst. mike
  13. Clutch switch is bypassed -- i.e. both wires are tied together -- I haven't followed that back to the dme and checked -- but for now, I'm assuming that the wiring is fine. I'm going to take the DME to a friends Boxster over the holidays and make sure it starts his car. Mike
  14. specialized ecu repair mike
  15. What signals at the DME are required for the dme to engage the fuel pump? pin 66 on my spec boxster is not pulling to gnd. My dme/immob/key have been tested and are good. mike
  16. That's your starter. It's not disengaging from the flywheel on its own. Not sure if you can access it easy enough and spray a little lubrication on it. Mike
  17. Pin 66 is =12v, so it’s not happy Pin 63 remains at 12v, not happy either. The dme was tested fine, and was programmed/modified to ignore the immob. mike
  18. Too much sealant blocking the oil passage. take the cover off, remove the sealant reseal with less sealant and you should be fine. Use new green plugs mike
  19. Not sure the car still has the SRS (since it's a spec boxter) --- I'll need to drag the Durametric back out and see what I can talk to -- I did at one point, but I've forgotten. Looking at the schematics -- clutch interlock could come into play as well -- even though the car has been converted to push to start and starter is not controlled by DME. Will have to check that as well
  20. Borrowed the o-scope. Looks like ~8v p-p yep missing tooth looks right and decent crank speed. i haven’t been able to verify no spark ... but I’ve got no fuel injector firing I was thinking along the lines if not SRS, maybe crash sensor. Roll over sensor, or something like that. i’m running out of ideas.... Need to crawl through schematics some more. i guess my only saving grace to my pride is this is proving to be a royal pita and has many folks stunped mike
  21. Back at it again tonite no tach bounce, no fuel injector firing (mood light) hooked up scope to CPS at dme i get life. going to noodle on that and game plan for this weekend. one possibility is how does airbag system normally talk to ecu? im 99% sure this has been deleted and circumvented... maybe something there has come loose? mike
  22. Definitely not the case -- will have to figure out why -- I did replace it -- maybe the new one is bad too (unlikely but possible), or there was some issue with the connector/line/etc. Mike
  23. Sorry for being offline -- I had several beach homes in the line of fire of Hurricane Michael -- so I have been a bit preoccupied. I did get the DME sent off and tested -- and its fine -- for good measure -- I had the immobilizer delete performed (it wasn't cheap -- but its a race car and I wanted to in theory reduce the source of other potential issues). I didn't get a chance to check pin 66 before I shipped it off. I did put the DME back in post modification -- no joy. No fuel pressure, and when I do do the fuel pump bypass, I get fuel pressure, but no start. I'm headed back out tonite to continue debugging. While I replaced the CPS -- I have not seen tach bounce while trying to start. I don't know how subtle the bounce would be -- on my old 944, it was fairly obvious. I'm tempted to try yet another CPS, they're not THAT hard to swap out. This is where I wish I had not sold my Boxster S -- I could pull the fuel pump relay -- and see just how much the tach bounced. Mike
  24. The StartLock relay is hardwired to VSS. I might have to figure out if I can tap into the loom to observe the exact signal.
  25. I still haven't found a car with coil on plug that I can access to test on. So I'm not sure, but I don't think so. I do note that if the pump even came on for a second -- it would pressurize the gauge and it would hold for awhile -- and this is not happening. Wish I could querry the DME and have it tell me what it thinks is going on. Mike
