RicksCarrera
Everything posted by RicksCarrera
  1. Thankyou ‘JFP in PA’. I found a tool that I took a chance on and it worked! It is ‘OTC 6999’. i have a attached a pic to illustrate.
  2. Hello all I have a 2008 Cayenne base w about 125K miles. I had the symptoms of a failed HPFP and a failed PCV valve. With the help of my manuals and mostly a few good youtube videos I have removed the intake manifold and the valve cover to replace the PCV membrane. With the engine laid bare it is obvious the intake valves are carboned up and require cleaning. I have done this with a combo walnut blasting carb cleaner and picking. All clean now. I have a fuel injector removal/rebuild kit and I have removed and cleaned and resealed and reinstalled the lower rail fuel injectors. Lots of videos on that. Now working on the upper rail attempting to remove the fuel injector I had no idea the upper fuel rail fuel injectors have an extension that connects to the fuel injector by a metal 'tab' or 'latch'. The 'latch' has broke free or separated and I have pulled the extension leaving the fuel injector stuck in the cylinder. I am hoping to receive advise on the best way to remove this injector. There is one video of a person that used this "tab' to make a fitting to extract injector and I have tried that with no success. I am wondering about drilling it out as a last resort. Of all the youtube videos of VR6 fuel injectors none have illustrated removal of the top rail injectors. I wonder if this is common. Seems a very poor design and an easy point of failure. I surely do not want to remove head to get at it. hope I get some suggestions. Many thanks. Rick
  3. Hi all I am looking at buying a 997.2 and was wondering if anyone with a membership to carfax would be willing to search the vin for me? If so, please PM me and I will forward the vin. Many thanks Rick
  4. Hi Jim
    Well I have just completed a major project. I have installed the LN dual race IMS, RMS, AOS, flywheel and clutch. It was a big job but doable.
    If you go with the LN bearing, the tool kit and instructions make that part of the job relatively straight forward.
    I am selling the toolkit if you are interested. This is my thinking... The toolkit is expensive. I paid $350. I would like to sell it for $300. I am happy to pay $50 for the one time use of the tool and then the next person can sell it for $250 if they like and so on.
    Best wishes. Let me know. Cheers Rick
  5. Hi All I am in the very final phase of a major project for my 2000 996 C2 cab with about 100k miles. I replaced the IMS, RMS, AOS, flywheel and clutch. A nice winter project! As with most things porsche, one needs patience, because there is always a fair amount of reaching and feeling and the need for just the right combination of tool and angle to get the job done. Following the workshop manual and many different posters here at renntech and rennlist and from youtube, I put the car on jackstands 24" above the floor. A lift would be better. I pulled the transmission, clutch and flywheel. The top transmission bolt requires a u joint and two foot extension and you need to reach around both sides of the tranny in order to place the socket on the bolt. I had bought the very expensive LN engineering dual race IMS(for my car) for about $800 and the pro tool kit for about $350. The Tool kit made the setup of TDC and locking the cam and pulling the bearing and installing new bearing relatively easy. I used a basic CPVC type 4"plumbing cap and carefully drove new RMS to 13mm from crankcase flange. The AOS was a bear to remove in one piece due to original permanent hose clamps. I was able to remove old AOS and install the new one from under the car using new fuel line hose clamps for the two small coolant hoses and a ~11/4" screw hose clamp for the bottom bellows hose. I used the old AOS to practice just the right way to install the AOS into position. Re installing the tranny takes patience. You need to be methodical about lining it up with an equal gap between tranny and engine all the way around, and that the bolt holes are lining up. It took me a while but it came together. I did a flush/bleed of the clutch and brakes, the conventional two person way, and it worked like a charm, no power bleeder. Just do not let master reservoir fall below max because the clutch pickup is high up in the reservoir. It is a big job, but doable. It was nice to be able go to work and leave it from time to time. I also had the tires dismounted and I am having the rims powder coated satin black for a new look. Cheers Rick
  6. Hi All I just flushed/bled my clutch and brakes after reinstalling my tranny were I had disconnected the slave cylinder. I used the two person conventional method and it worked like a charm. I attached a clear hose from the nipple to a bottle where the hose end is emersed in fluid. Person one (wife) presses pedal, I open bleeder nipple and allow some fluid to flow, then close bleeder nipple then person one releases pedal, repeat. In the case of clutch pedal, person one returns pedal to normal position for the first few bleed cycles. I kept the fluid in the master full and had no problems, no power bleeder.
  7. Hi Rod The vertex instructional video shows how to pry the bearing seals out with a very small/fine screw driver type tool. It is that easy, and then simply repack with grease by hand. It is easier to repack the bearing when the flex disk has been removed and the shaft hangs down. With the tranny in neutral it is easy to turn the shaft. I am pretty sure thou, that the bearing seals can be removed and the bearing repacked with the flex disk and shaft connected.
  8. I have two 2008 cayenne base, and the center support failed about the same time on both cars. I used the Vertex solution, because there is really nothing wrong with the shaft or the shaft bearing. Following the video tutorial, it is not a difficult job, thou it takes longer for a slow poke like me than the video tutorial would imply. In this order, loosen the flex disc bolts, remove the bracket support and cut away the original bracket, remove flex disc, clean the outer bearing surface, repack the bearing, install the new flex disc, install the new vertex support and bracket. The weak link now becomes the bearing itself. There was very little or no grease in my bearings, and they were in good shape. Now they are repacked with grease and I hope the shaft lasts at least as long as a replacement shaft would have. One could even make a case for repacking that bearing from time to time, say every 50k.
  9. Hi All I am also looking at this lift (quick jack 5000xl) for my 911 and Cayenne. Regarding the lifting height, I read a max height of 21". Is this enough height to change the clutch on the 911? Is there enough height at 21"to drop the engine and/or transmission. many thx for any input. Rick
  10. Hi all Can anyone tell me the correct size (Torx bit?) socket insert for removing the caliper? The manual calls it (NR.33 socket wrench insert, multiple tooth with pin guide). Thx. Rick
  11. Hi all I have a 2000 996 cab. The top function is intermitant when using the switch, but works fine using the key in the door. I am thinking I have a faulty intermitant switch, or the ground at the park brake is intermitant. When pressing the switch, the top either works or it does not work, it does not fail during operation. When the top does not function using the switch, the dash light still illuminates and there is a slow 'clicking' sound, so it seems the control module is getting power. Does anyone know if, when using the key in door for cab top function, the ground is bypassed? If so, perhaps the problem is with the ground, and not the switch. Thank you to anyone with thoughts on this. Cheers Rick PS I have topped the hydraulic fluid level
  12. You need the workshop manuals. They detail pretty much any fault and the required service. Also the durametric does have a function for fault codes and a calibration function that works for me.
  13. The 2008 model also has a a/c drain duct that protrudes through the firewall on the front passenger side. It can be reached from the engine compartment to the firewall on the front passenger side. It is a rubber duct/spigot the size of a straw with a flap that can stick closed which causes a backup of water in the air vent systems and water dripping on the carpet. No service is required, just reach in and ensure the duct can drain.
  14. You absolutely can reach the ac/heater drain tube on a 2008 V6 Cayenne from the top. Lift the engine hood and reach for the tube which protrudes from the engine firewall ( passenger side top of the footwell ). Use a flashlight to help locate it, then reach for it. I did and the water came gushing out! Cheers Rick
  15. Hi I was also noticing a wet drivers side flootwell, not during rain. During my trouble shooting I noticed a little water dripping onto the footwell from above, but just a little, and not enough to make the footwell wet. I was worried that a water drain line from the heater/ac unit was leaking and a big job might be required removing the dash and glove box etc. to get at the ac unit. Further troubleshooting revealed that there was some water being pushed out the left rear passenger ac/heater vent at the floor under the drivers seat. At this point I realized what was happening, and thank goodness it is very simple. The AC water drain was plugged causing the water extracted from the air in the ac/heater unit to backup and for some reason this water was mostly blowing through the left side plastic ac/heater vent lines and leaking at the low point in the drivers footwell with the remainder of the moisture pushing out the vent under the drivers seat. Some have this happen on the passenger side. The ac/heater water drain is located on the passenger side footwell forward on the firewall. The drain slopes through the firewall and you can see it when you lift the hood and shine a light at the firewall on the passenger side. You can reach for the drain hose. There is a small flap. With my baby finger I lifted the flap and about a pint of water gushed out. Simple as that, plugged ac water drain cleared...no more wet floor. Cheers Rick
  16. Hi all I am going to re and re the spark plugs on my 2008 V6 Cayenne. I have the shop manual but was wondering about the technique for pulling the coils...I don't want to break them. Is this a straight out pull and how much force would be required. I do not have the special coil puller tool but was wondering if a coat hanger wire tightly wrapped around coil will work...I'll report on that. Thx for any info. Rick
  17. Hello All I was browsing online for brake pads and I noticed ceramic type pads that boast 80% less dust, and then the standard semi metallic. I have not inquired about whether rotors need to change, and I would not change rotors to accommodate new pads. Does anyone have experience with the ceramic type..are they compatible with steel rotors, how do they stop and wear and is there dramatically less dust? Thx Rick Thx to all that replied. I decided on the Hawk HPS semi-metalic and have changed both front and rear. I was able to reuse the sensors by prying them out carefully. So far so good!
  18. Hi all As I contemplate between a 2009 Cayenne both the V6 and V8 and a 2009 Toureg V6 TDI, I'm wondering about long term (major) maintenance issues. Does either the V6 or V8 engine have a timing chain that does not require servicing? Any other general comments on reliability would be greatly appreciated. Thx Rick
  19. Hi All Has anyone experience with removing the side mirrors? I will attempt to attach pics to be more clear. There is a screw shown in the pic in line with the window that looks like would release the interior trim. I have the manual but there is no detail on how to remove that trim piece except to unclip, and same with mirror. My question for anyone is how do you unclip the interior side mirror trim piece.
  20. Hello all I have a '99 C2 cab and would like to repaint the bumper and hood and have a clear bra (3m?) installed. Wondering how well the bra stands up after a couple of years and if rock chips show up on the clear bra? Any recommendations if I were to change the front bumper? Thx Rick
  21. Hi All Below is some of what the shop manual has to say on the convertible top function. The actual trouble shooting is quite specialized because special tools are required. It sounds like you may have a faulty micro-switch I am having a problem with my top also, it is in the convertible top fully open (or down) position. When I actuate the top switch I get the click clack sound from the control module but no action. Recently I topped up the hyd fluid (as per Izzy's DIY)to correct an intermitant cab top function and the top worked perfect. I have two questions for those who have moved the top by manual method; If I put the top up by the emergency (manual) method, will the top need to be calibrated? Does anyone know if the durametric code reading software can read and clear top function codes? This is alittle long and no diagrams 911 Carrera (996) Convertible-top diagnosis General information Diagnosis The monitoring of signals by the convertibletop control module enables the system to perform reliable, precise diagnosis. Further, certain additional functions, such as e.g. test of drive links and of input signals can be activated using the Porsche System Tester 2 and their function checked. General infonnation Convertible-top control Each single step of the opening/closing process is only executed on condition that the preceding step was performed correctly. If a single step is not confirmed within a given time, the actuation of the drive motor is interrupted. The fault memory can be read out and erased with the Porsche System Tester 2. The diagnostic socket is located below the knee guard on the driver's side. At the beginning of a process, the limit switch or potentiometer values have a particular configuration, which is examined by the control module. The control module monitors itself and the connected components. The results are read out via the diagnostic interface. 625_96 61 01 Diagnosis/troubleshooting, convertible top Printed in Germany -II, 1998 99661Dl 61-D3Convertible-top diagnosis 911 Carrera (996) Overview of convertible-top components Rocker switch 1 2 Warning light Micro-switch, latching hook (windscreen frame) 3 Micro-switch, convertible-top latch (convertible-top side) 4 Potentiometer I convertible-top interrogation 5 6 Control module Micro-switch, convertible-top compartment lid (locked) 7 Potentiometer, convertible-top compartment lid interrogation 8 Micro-switch, left/right rear section flap up and down 9 The convertible top is actuated if: Terminal 15 is connected via ignition. The parking brake input is connected to ground (parking brake engaged), No speedometer signals greater than 5 km/h (3 mph) are present. Engine compartment lid is closed (input not at ground potential), 61 -D 7 61 01 Diagnosis/troubleshooting, convertible top Printed in Germany -11, 1998 99661Dl Fault memory Overview of possible faults 1 Switch position implausible 2 Button short to ground 3 Convertible-top pot. fault 4 CTCL pot. fault 5 Timeout error 6 Calibration necessary 7 Supply voltage 8 8 61 -D 12 6101 99661Dl Diagnosis/troubleshooting, convertible top Printed in GenT1any -II, 1998Convertible-top diagnosis 911 Carrera (996) Fault, Fault code Possible causes, elimination, notes Test point 1 Switch position implausible Fault code 01 This fault is only stored in the memory when an operation has taken place (button or comfort function with the key). 1. Check response of micro-switches of rear section flaps left and right. A defective micro-switch must be replaced. Refer to Servo No. 61 41 19 2. Check response of micro-switch in convertible-top latch. If the micro-switch is defective, replace the convertible-top latch. Test point 2 Button short to ground Fault code 02 1. Check pin 1 to pin 4 for continuity (bitmap on "close" switch), check button pin 2 to pin 4 for continuity (bitmap on "open" switch). 2. Measure resistance of wires 1 and 2 to one another with the ohmmeter. Display 1.8 -2.0 K .0. . 6101 99661D14 Diagnosis/troubleshooting, convertible top Printed in Germany -11, 1998 61 -D 14(;onvertible-top diagnosis 911 Carrera (996) Fault Fault code Possible causes, elimination, notes OJ 0 , -. Test point 3 Convertible-top pot. fault Fault code 03 This fault is only stored in the memory if the voltage at the input of the convertible-top potentiometer exceeds or falls below the operating range. 1. Switch ignition off and remove ignition key. With test adapter 9619, 9636 and pin template 9636, measure the resistance of the convertible-top potentiometer at row I, pins 12, 21 and 24 with the ohmmeter. If the display 00 .Q appears, the convertible-top potentiometer must be replaced. Refer to Servo No. 61 66 19 2. Switch on the ignition and measure at row 1, pins 12 and 21, with the voltmeter; nominal value (display) 0.4 -4.4 volts. If there is no voltage display, replace the control module. 3. Calibrate the convertible top Test point 4 CTCL pot. fault Fault code 04 This fault is only stored in the memory if the voltage at the input of the convertible-top compartment lid potentiometer exceeds or falls below the operating range. 1. Switch ignition off and remove ignition key. With test adapter 9619,9636 and pin template 9636, measure the resistance of the convertible-top compartment lid potentiometer at row I, pins I, 3 and 5 with the ohmmeter. If the display 00 .0. appears, the potentiometer and drive motor must be replaced. Refer to Servo No. 61 70 19 2. Switch on the ignition and measure at row 3, pins 1 and 3, with the voltmeter; nominal value (display) 0.5 -4.4 volts. If there is no voltage display, replace the control module. 3. Calibrate the convertible top 61 -D 15 61 01 Diagnosis/troubleshootin~~, convertible top Printed in Germany -11, 1998 99661D14Convertible-top diagnosis 911 Carrera (996) 8 Fault, Fault code Possible causes, elimination, notes Test point 5 Timeout error Fault code 05 This fault is only stored in the memory if an electric motor is actuated and does not reach the limit position within 6 seconds, or the potentiometers of the convertible top and CTCL do not show any change in voltage within 3 seconds. To check the micro-switch input signals, select the input signals which appear in the menu: Latch locked, Latch unlocked, Convertible top, Convertible-top compartment lid side flaps, Latching hook. Actuate the micro-switch manually (press it) to read the response in the bitmap positions of the tester display. -;~ 0 192_98 If the convertible top is between "Convertible top closed" and "Convertible top forward" and if the "Convertible top raised" input is connected to ground (contact for micro-switch of convertible-top latch does not lie against the top edge of the cowl panel and does not switch), examine the tension of the convertible-top covering using the left and right tension cables or, if necessary, loosen by 1 or 2 turns so that the contact lies against the top edge of the cowl panel and switches. Diagnosis/troubleshooting, convertible top Printed in Germany -11, 1998 6101 99661D14 61 -D 16911 Carrera (996) Convertible-top diagnosis Fault, Fault code Possible causes, elimination, notes 193_98 If the convertible top is in the forward position (diagram) on closing, check the response of the micro-switch -unlocked or not unlocked (small diagram) -in the convertible-top latch. If the micro-switch is defective, replace the convertible-top latch. 194_98 If the convertible top is in the rear position (diagram) on opening, check the response of the micro-switch -unlocked or not unlocked (small diagram) -in the convertible-top latch. If the micro-switch is defective, replace the convertible-top latch. 61 -D 17 61 01 Diagnosis/troubleshooting, convertible top Printed in Germany -II, 1998 99661D14Fault, Fault code Possible causes, elimination, notes 195_98 If the convertible top is in the centre front position (diagram) on closing, check the response of the micro-switch -not locked or locked (small diagram) -in the convertible-top latch. If the micro-switch is defective, replace the convertible-top latch. 8 196_98 If the convertible top is in the centre rear position (diagram) on opening, check the response of the micro-switch -not locked or locked (small diagram) -in the convertible-top latch. If the micro-switch is defective, replace the convertible-top latch. 61 -D 18 6101 99661D14 Diagnosis/troubleshooting, convertible top911 Carrera (996) Convertible-top diagnosis 197_98 If the convertible top is in the closed position (diagram) and the latching hook has been actuated, check the response of the convertible top (CTCl) micro-switch or adjust the Bowden cable of the central locking hook in such a way that the micro-switch switches. A defective micro-switch must be replaced. Refer to Servo No. 61 81 19 If the convertible top remains in a position not described here: 6. Switch ignition off and remove ignition key. With test adapter 9619,9636 and pin template 9636, measure the resistance of the convertible-top compartment lid potentiometer at row 3, pins I, 3 and 5 with the ohmmeter. If the display 00 .0. appears the potentiometer and drive motor must be replaced. Refer to Servo No. 61 7019 7. Switch ignition off and remove ignition key. With test adapter 9619, 9636 and pin template 9636, measure the resistance of the convertible-top potentiometer at row 1, pins 12, 21 and 24 with the ohmmeter. If the display 00 .Q appears, the convertible-top potentiometer must be replaced. Refer to Servo No. 61 66 19 61 01 Diagnosis/troubleshooting, convertible top Printed in Germany -11, 1998 99661D14 61 -D 19 Printed inConvertible-top diagnosis 911 Carrera (996) Test point 6 Calibration necessary Fault code 06 This fault is stored in the memory after 1000 actuations or if fault code 03, convertible-top pot. fault, or fault code 04, CTCL pot. fault, is entered. 1. Read out and delete actuation counter 2. 2. A newly installed control module has not been calibrated. 3. Proceed as described in test points 3 or 4. 4. Calibrate the convertible top Test point 7 Supply voltage Fault code 07 1. Check the battery or alternator. 2. Inspect the plug connection on the control module for corrosion, 8 8 6101 99661D14 Diagnosis/troubleshooting, convertible top Printed in Germany -II, 1998 61 -D 20 Germany -11, 1998
  22. Is this correct that the Durametric code reader software can read and clear proprietary items such as airbag lights? If so, awesome! Thanks Rick
  23. Hi All To conclude, I was pleased with the gahnn seat cover kit. My seats look as good as new actually better, there is no vinyl on the side of the bolsters v the partial leather. The installer did an ok job of it, but the cautions on work quality in this thread above are wise. There are two small leather wrinkles that were not present on the original seat, but it might be something you would expect from 'real' leather seats. They look great. Total cost was 1350 for the seat kit and 300 labor for the re and re plus tax. cheers
  24. Mine has about 60k and had no issues. Love that car.
