c70Pete
Everything posted by c70Pete
  1. http://www.motortrend.com/roadtests/coupes...provements.html looks like Porsche has had enough engine failures and chosen to follow new 997.2 engine modifications and apply them to the Cayman S 3.4 !! this should be one quick car... but I think they kept the gear ratio slightly taller than the 997..... in PDK apparently its a rocket!! lets see how good this engine is or if another "new" engine brings "new" problems !! fingers crossed.
  2. Togilvie, that's good to know.... I have a ticking and we believe it to be something lose on the exhaust manifold a bolt or so... that ticks with each exhaust pulse... were hoping its that... otherwise were looking at a bad lifter? it ticks faster as rpm increases.... its going to the shop this weekend so I'll let you guys know what we found.... Togilvie... that's exactly the symptom my car had... I have a 99c2... I think its your bearings ... does it happen on the right rear side of the car? do you still hear the tick as RPM increases or does it go away? what is the mileage of your car....
  3. Only X51 engines. thx Loren, what about the 2005 and beyond 3.6 and 3.8 engines... did they have any type of oiling implements that were not present in the 2002-2004 3.6 engines?
  4. VarioCam Plus is quite different As a Contributing Member you can read the 4 page write up in the MY2002 Technical Information Book. Looks like I might have something a bit deeper going wrong. Sat listening to the car tick over last night and it started knocking for no reason and then stopped again after a while. Think there maybe some open heart surgery required in the new year. Oh woe is me. I have the same sound you have... coming out of the right rear of my car.... took it to porsche... scored cylinder #6... the explanation from a tech is probably the bearings are worn out and it causes the knocking at low rpm.... when I rev my engine past 4000 rpm the knocking disappears... does your knocking disappear over 4000 rpm? I can't say for sure what your issue is but are you burning a lot of oil as well?
  5. I thought suncoast porsche provided a performance oiling kit for the Carrera... cost was about $1K sounds like a worthwhile mod... I recently scored cylinder #6 at a recent track event... probably due to oil starvation... do the 3.6 engines already have this build in?
  6. did anybody read the article in December's issue of EXCELLENCE? - about the m96 motors... from 99 right to 2008.... ALSO BY JIM PASHA :clapping: I guess time really shows how good an m96 motor is.... does anybody know if the 2009 3.4 caymans have an intermediate shaft?
  7. a 3.6 with 46K on it and it failed? what was the diagnosis... hmm.... apparently they didn't do much between the 3.4 and 3.6.... design... I know its got more parts in it but they are still failing.... a common failure seems to be the bearings at the intermediate shaft (IMS)... .I guess that's why in the new 997.2 they have done away with IMS... cause they could never get it right... I've read so many failures on these motors that its clear to me you won't be enjoying them for "years to come"... and what is porsche doing about it... NOTHING... making clients pay for a new motor... where companies like BMW when they had bearing failures on their E46 M3 they warrantied all these motors for 160,000 km.... now THATS standing behind your product.
  8. get a warranty!!! you will not regret it... .the rattling sound is not good... it will manifest itself in an engine failure one day... warranty is best $$$ you will be spending... @ 123,000 km on a 3.4 I'm surprise it hasn't grenaded yet...
  9. Togilvie, that's good to know.... I have a ticking and we believe it to be something lose on the exhaust manifold a bolt or so... that ticks with each exhaust pulse... were hoping its that... otherwise were looking at a bad lifter? it ticks faster as rpm increases.... its going to the shop this weekend so I'll let you guys know what we found....
  10. so it was a rattle and not a ticking.... and it did not increase in frequency i.e faster rattling or more tapping as the engine revs increased? hmmm... maybe we have a bad lifter instead?
  11. From first-hand experience - the "IMS Death Rattle" is not uncommon. I thought it was a water pump, then maybe a belt tensioner/pulley, then it just let loose and dumped 9 qts of M1 20w-50 on the garage floor. The rattle was probably present from the first time I noticed it, until it worsened over the course of 200-300 miles in a week - then it failed. Hey Doug, what exactly did the rattle sound like....? we have a 996 that is making a loud ticking that seems to be coming form the right rear of the car... and it gets faster as the RPM's go higher and doesn't want to go away... is this what your car sounded like? P.
  12. I have 265/35- 18, for which 285/30-18 is a Porsche approved alternative. Tire height is a percentage of its width, hence two "tire heights" in addition to the rim size will give total wheel/tire diameter. The circumference is PI (~3,14) times the diameter. The circumference of the 265/35 should be: PI * (2 * 26,5 cm * 35% + 18" * 2,54 cm) = 201,91 cm The circumference of the 285/30 should be: PI * (2* 28,5 cm * 35% + 18" * 2,54 cm) = 197,35 cm Hence replacing the 265/35-18 with 285/30-18 will reduce rolling distance by approx 2,3%. 2.3% is ok... its when you get beyond 4% its start to play havoc with the ABS system. what model of tire are you running for 265/35/18 ? what model of tire are you gong to run for 285/30/18... ?
  13. Yes, the wider rears will give more understeer, that what I wanted to counter-act with the adjustable sways. The wider tires will provide more lateral grip, and thereby allow slightly higher corner exit speeds. I do not think the weight difference will play make any measurable difference in how fast the car is or feels. If anything the slightly smaller tire circumference of the 285/30 compared to the 265/35 will make the car accellerate better! Anyway, have you got the M030 / GT3 Sways combo on your car? Hi, interesting theory.... I have the ROW M030 with 17" 225/45/17 and 255/40/17.... when my rears wear I will get 265/40/17 - the ROW 030 kit dials out some of the nasty understeer found on the 911 ... but going 285 is pretty wide... you think the car will be faster with 285 in acceleration.... what percentage difference in diameter exists between 285 and 265?
  14. going wider in the rear will give you more understeer... stay with 265 in the rear EURO M030 and GT3 sway bars are an excellent combination.... but stay away from the 285 in the rear... it will make your car slower as those tires weigh more *and* create more friction.... Michelin PS2 is a nice 18" tire that is lightweight for 265 size...
  15. forget headers... go with 200 cell hi-flow cats from a reputable manufacturer like Cargraphic... then you'll see more midrange and top end...
  16. interesting... I LOST power with the EVOMS intake on my 99 C2 and went back to the stock airbox & K&N filter with great results... I haven't tried the plenum yet... when you flash your car with the GIAC flash I'd be interested to hear some feedback given the mods you have...
  17. Don't waste your money, not much you can do to the engine, other that supercharger upgrade about 10K, or buy a turbo 996 instead, other than that you are going to spend a ton of money for no more than 10 HP. Thanks for your reply and sharing your insights, Cesarfl. I'm not looking for maximum raw power here as I actually like the characteristics of the naturally aspirated engine for everyday driving. The upgrades I'm looking for make a noticeable difference at lower revs. If I end up with about 30 to 35 additional hp (incl. exhaust, air intake, plenum) and related torque gains, that's a 10 plus percent increase in total hp. I agree I seriously doubt you will get what these folks are advertising on a normally aspirated car. In some case folks lose midrange power and torque. I agree with Loren... I don't know about 35 hp.... change in powerband is more likely.... however.. I also have a 99 C2 with with PSE and found the GIAC ECU flash to be worthwhile upgrade... feels good after 4500 rpm and removes the lethartic spot in the 3.4 engine @ 3200 rpm.... I would recommend the GIAC flash and if that's not enough then some 200 cell hi-flow cats from Cargraphic (excellent quality) for more top end punch... the GIAC flash will adapt nicely to those cats... but that's it.. don't bother with headers.... I also don't know about the plenum... questionable.
  18. maybe oil is leaking/sweating from your variocam seals? could that cause such a high rate of oil usage...?
  19. Has anybody tried the Yokohama Advan AD07 on their 996? hearing good things about them but would like to hear somebody who has any track experience with these tires?
  20. I have 17" rims on my 99 996 and plan to do about 15-20 track DE days this summer.... the stock size are 205/55/17 and 255/40/17 Is there a disadvantage go going with a wider tire size in the front... say a 215/45/17 or a 225/45/17... I checked the rolling radius for both tires and the best match would be the 225 but the 215 ain't far off..... will this reduce understeer in the car.. and most importantly is it safe for tracking?
  21. Anybody try the new Bridgestone RE01-R tires... on the track? cheers P.
  22. I do have a source for them but if they don't have them in stock they can order them from Europe and it will take 12-16 weeks... I'm currently waiting for a set for my C70; I hear they are a great pad period so I took the plunge.... You can get them here: Parts for Imports ask for Mark Papadopoulos 856-665-2300 regards, Pete
  23. pelican parts doesn't carry the mintex C-tech 1144 compound... just the standard ones... you want the 1144 compound.
  24. anybody try 200 cell cats... I hear that *is* a worthwhile upgrade and lets your engine rev faster beyond 4000 rpm....???
  25. I would clean the wiring connector and inspect it for damage. Thx Loren, is this something I can do myself or does it involve extensive work...?
