shanawany
About shanawany
  • Birthday 10/24/1986
Contact Methods
  • MSN
    shanawany1@hotmail.com
  • Interests
    Fix And repaire Porsche
    jordan
    Other
    Porcshe cayanne S
shanawany's Achievements
  1. Hi Mate i need eeprom ic number for Rear end electronic porsche cayenne 2013 please Sent from my LYA-L29 using Tapatalk
  2. Can any Body Help me by picture how to install Camshaft And Head Cylnder For porshce Cayanne 2005 V8 ?? And how Much the ftltb ? For head And Camshaft
  3. You just need to check the Socket !! in the lights and make sure its connect very well.
  4. that becouse the weather !! it will be more heavy than 0w/30
  5. sounds like brake light switch faulty !!! and about PSM FAILARE.. dont worry just move ur car for 100 Maximum and everything will be ok .. but you should to call Dealer and let us what they told you ?
  6. You have to Change the Fuel pump !! Becouse the right pressure its 4 par !! but when u start idling and reads little more 3.4 its not pressure very well Check another car and u will see the deffernt.
  7. you dont have to change all coils.. JUST CHANGE THE BROKEN ONE !! but the Company change 8 coils :S !! and it will be so cost for you .. and about the plugs if the spark plugs new just clean the head and put it again !! but if u want the right way put the new one ;)
  8. you have just to change the cam housing Gasket and everything will be ok .. if you dont fix it fastly u will loose the ingtion coil also !!
  9. There's another way .. just bring the M10 and put inside the Socket and when you put it hardly .. let some one help you to remove it slowly . Note : it will be broken when u finish.
  10. U r Ryt And yeah sometimes it will be wrong !! but what i told you .. Everything is PERFECT AND THE 3 HOSES THEY R IN THEY PLACES.. AND SOME HOSES FOR HEATER I THINK !!! AND I U WANNA MAKE SURE THAT THE SYSTEM COOLING IS OK SHOULD U TURN THE AIR CONDITION BUT IN HOT WAY.. I HOPE I CAN FIND THE REAL PROBLEM !!
  11. About the Battary is it Cayanne 6V or 8V , if its 6V its 95AH And if it 8V its 110Ah. About the Four Wheel System Faultty check the Motor Postion in The transfare Case About the PSM FAILARE... Check the Airmass Sensor !!
  12. yeah , everything is working but the fan working so late !! its start on 100c !! And the Air Condtion is Working too Also ther's no No Air in System ... and if the Air in sytem it will be start the High speed on the fan.. but everything GUYS is normal .. but why WHEN I CHANGE THE PIPE COOLANT i hade this FAULT ???
  13. Removing the little black air pump first will make life MUCH easier. Reinstall torque stabilizer bolts to the body and to the bracket at 44 ft. lb. each. The bracket to engine torque is 23 ft. lbs. on the biggest, fattest bracket bolts (M8 x 45mm) and 7.5 ft. lbs. on the smaller of the bracket bolts (M6 x 40mm). New plugs are torqued to 22 ft. lb. w/ reinstalled old plugs to 19 ft. lb. Coils themselves are torqued to 7.5 ft. lb. and the Design Cover fasteners to 3.5 ft. lb. The secondary air compressors on the firewall are torqued to 7.5 ft. lb. and I removed them from their brackets and used packaging string looped through a bolt hole to the hood to hold them up and out of the way.
