ekstroemtj
Everything posted by ekstroemtj
  1. I know this was discussed already many times but i cant solve this water problem. My first S stay outside now for 3 years. Engine has a scored cylinder. Thats why no moving. Since i bought my Turbo the old car was moved only a few times for some km. Of course there was always a water problem which i could solve but now... Nothing. I took apart the a pillar trim and the headliner. Could get acces to the hose. Disconnect the hose from the reservoir which is sitting in the sunroof frame. Found a hose with onother green smaller hose inside. This is i didnt know. The green tube was split. Dont think its normal. I used a bowden cable to clean the smaller tube. I can get inside for about 120 cm. Then its stuck. Normal or it should stick out somewhere? I am really dissapointed this cant be solved. Would like ask: The inner green tube has to be completely inside the grey hose or it has to stick outside and ending in the reservoir? How to replace the entire green tube if its closed and cant be cleaned? Any help which can take me out of this is welcome.
  2. Fixed. Gaskets look pretty worn after 10 years. I am wondering if they can break apart and cause even more serious damage if smaller parts going to some oil channels or somewhere else.
  3. Thank you for writing. Will try to get a new vacuum hose. Maybe this will solve the overboost. The valve which you pointed to is already new. If the car is tuned? I dont think so
  4. Reminds me to my constant problems with my CS. The dealer changed parts like hell. Sensors, MAF, throttle body, etc. hundreds if not thousands. In the end i believe it is just a low voltage problem. As soon as i had new batteries the problems dissapeared.
  5. Thank you. I ordered the parts. Just wondering if i should change the magnetic valve too which is sitting there?! I have constant codes there. Camshaft position ..... P00011 Changed the sensors didnt help
  6. Thank you. I am in Germany. Must find a tool shop where to get it.
  7. Somebody know whats the part number from this seals?
  8. Or maybe this is tje valve cover?! I see there is some kind of seal / gasket on the place where the plug is sitting.
  9. This morning i wanted to check my coils. Very bad surprise i found in coil duct for drivers side cylinder no. 1. full of oil. Take it away as good as possible with a tissue. This is the head gasket?
  10. I bought some with recess in the center but dont fit. Must be different kind of. Your picture are the right ones. Thank you
  11. Please can somebody help me with this tool. What is needed to disassemble the MAF from the housing. Cant find the right tool in my garage. Thank you
  12. May i ask you how you fixed this vacuum hoses? You cut the damaged parts and how u connected the 2 ends?
  13. On every Cayenne which i had it was always trouble with This small connection which is near the intake pipe. On the picture here seen as red. Is there any possibility to replace it with some aftermarket pressure hose? I have a constant overboost code in my code reader and as hahn pointed out it could be together with some false reading because there is something wrong with the vacuum lines. Any help is welcome.
  14. I am glad you found the problem. Are you talking about this parts? Found it in onother forum: http://www.6speedonline.com/forums/cayenne-955-957/18559-hyperboost-hx-diverter-valves-installed.html
  15. What happens to your engine? Could you find out anything?
  16. The wiring sub-assemblies come in left and right and Halogen or Xenon. I need to know which headlight (Halogen or Xenon)? Also, some of the early cars need to be ordered by VIN - so please PM me your VIN also. I have send you my vin. Thank you
  17. Loren its not exact the same topic but would like to ask you if you have a name/ part number for this headlight Wire string. Mine looks terrible and i belive thats alsoa reason for headlight problems. Thank you.
  18. I still dont believe it the water pump. Sounds much more serious. Are you driving the car? Any sign of smoke when you starting? Did you check your oil level? Anything missing? How is the knocking when your engine is cold and how it sounds when its warm?
  19. Dont want to scare you but this issue every Cayenne owner is worried about. If you search here for piston slap or scored cylinder you will find a lot of messages. This noise i am very familar with. It happens with my first cayenne s. Solution is: you will have to rebuilt the engine. No need to say this is expensive. In which country you are located?
