ekstroemtj
Everything posted by ekstroemtj
  1. I have changed the cable but unfortunately didnt change the problem. :-(
  2. It would not be my first choice to get it apart but you could try with a screw driver Go into the gap which is already there or use a coin. Try. Or like you say you want to disconnect it from the turbo. I had to do it because my air hose was broken. little bit more work. Take away all the plastik protection under the car. Or you take away the wheel well liner to get access to this place. Lewis would say.... when you are there you can check the connections of your DV and the tubes and hoses arround for any visible leaks or damages.
  3. On your picture you marked it with a red arrow. Thats the place where its seperated. You can use a bit force. Important you gran one hand where the MAF is and your other hand directly where the clamp is sitting. Wiggle. On your picture its already open a bit. Maybe stick it together and try again.
  4. I did the same many many times in the last weeks. And yes if you are using to much force you can brake the hose where the flex part is starting. Best way you take one hand one the part which is flexible and orher hand to the part where MAF is sitting. You need to wiggle a bit and it will go apart. You can use a bit of WD40 on the place where the hose clamp is. Makes it more easy.
  5. Mark... just read your old post. I am hunting for my overboost reason. You mention water temp gauge can be a culprit. I bad thermostat too?
  6. bigbuzuki... thank you very much. I will try this. Should be easy to replace. Will report the result
  7. Its not a matter of low voltage. I have 2 new batteries. Driving arround without problems but: the "P" problem still excists. no illumination on the shifter for selected gear. according some forum members i need to check the wiring under passenger carpet for broken or bad wires.
  8. Great job! According your post and the pictures i understand you replaced only the broken sections? Not the entire line from N75 to wastegate?!
  9. thank you. this is also a work which is waiting for me.
  10. the better drive habits didnt last long. running is going to be the same like before. almost. i have always a one time wonder when i remove and reinstall the MAF the car is driving very good for some miles after this job. what could cause this phenomenon? can i messure the voltage at the MAF connection? what reading i should see? Thank you
  11. So today at least i was able to change the air hose which is going from the turbo to the part where the MAF is located. Little bit teight everything down there but in the end could do it. Which surprise, the car runs better now. Couldnt feel the hesitation right now while driving. I will report how it will be next days.
  12. Today i had time to continue to work on this. Have now 2 fully charged batteries inside. Still the same. Message on the display and the missing click clack when you put in the key and take out the key from ignition. The click clack is only working without the green circuit board. Strange
  13. I cant get very much for the car. Thats the problem. So better to continue to drive than to give it away for a small money. If you open internet here you find hundreds for sale. Most of them overprized.
  14. I would say depends on the previous owner. If somebody will buy my car one day he shouldnt have problems. I changed almost everything
  15. Hey! Dont be like this. Not everything what is coming from here is so bad
  16. Sorry could not do anything with the car last 2 days. Always to late at evening. Just measure the battery. Dropped from 12 to 10,90. thats bad :-(
  17. Guys ! Thank you. Lots of interesting information. looks like i have to check the situation under the car like bigbuzuki explained. Lewis the battery situation i will check at evening. I will messure at the jumper points and see what the reading is after one day sitting.
  18. Maybe i will just swap the battery from my turbo to this car and see how it works. If no change, no need for a new battery
  19. So you want to tell me this battery is toast again?
  20. Lewis, i try to track down the drain problem by using a method which i found on you tube. Used the voltmeter and pinned every single fuse if there was some flow. All what i found is the fuse for the plug in connectors. Of course this problems are running down a battery very fast. No driving for some weeks and the battery is down. I charged . When the car is running its showing 13,8 in the engine compartment at the jumping connectors. Engine shut off its showing now 12.00
  21. Thats the point. Its going to P and shifting is ok. You just dont hear the click when putting in and out the key. I guess it must be something electric. Otherwise it wouldnt work when taking out the green circuit board
  22. You even refer to the part number in a different topic. But i cant find a part diagramm showing the location.
  23. Thank you. But where this cable could be. Nothing which is looking similar on the shifting assembly.
  24. Thank you for this post. Are we talking about this cable with the BLUE head?
