geoff
Everything posted by geoff
  1. Here's the update so far; I'll provide the answer when I find out... Car sat from Monday to Thursday in my garage when I was out of town. Spoke with the dealer service manager on Friday - couldn't get in, but he suggested hooking up a battery charger, or at least the Porsche battery maintainer (I used the battery maintainer). Car had been starting just fine, but figured it couldn't hurt. Go out for a drive on Saturday. Car starts fine, but battery light is on. Drive a few miles, during which the light occasionally goes out, then comes back on. Head up a canyon road, then the ABS light comes on, then a little while later the airbag light comes on, go into a tunnel and all dash lights come on and the car dies. Coast over to the side of the road, car won't start. Didn't lose the radio code, and fortunately the emergency flashers still worked. Flatbed tows are expensive ($8 / mile) after the free AAA 8 mile tow :o
  2. And the answer is :( They all do it! Took the car in for an oil change at just under 8K miles and the brake problem. My service advisor was finally able to reproduce the problem on a steep driveway, and on Friday had another 997 in for service, which he took to the same driveway, and it had the same problem ... err, "feature". It's definitely ABS related. He hasn't tried it with a 996, but my Boxster doesn't exhibit the same symptoms in our driveway. They sent a "P tech" (sp?) in to Porsche, and I asked them to also check with the district service manager when he's around. I told the salesman this afternoon when I saw him, and he wasn't happy about the problem.
  3. Driving home through the canyons from the German AutoFest in Ventura, my battery light came on a few times. On solid for a few minutes, then went out for a minute or two, then back on for a while. Original battery on a 2001 2.7 5 speed. Never had any problems starting, don't use battery maintainer, battery never drained, no radar detector, doors never locked at home, so basically no drain from alarm. Owners manual says it's either "defect in the battery charging system or broken drive belt" - no real helpful at narrowing down the problem. Car wasn't overheating. Any thoughts / suggestions? I'll call the dealer in the AM (it's not under warranty - 4 years were up in February), but better to be armed with some knowledge in advance.
  4. I vaguely remember something about cruise control not working if a brake or tail light is burned out. I'm in a hotel room on the east coast this week, so not easy to track down, but it was probably on one of the main Porsche boards you would expect (here, PPBB, Rennlist, Rennteam, etc.) Have you checked all your light bulbs to make sure they work?
  5. I'm thinking about getting a new floor jack - one that will work on the Boxster and 997, as well as for my truck ('88 Toyota 1/2 ton pickup). Any recommendations? Sears? Harbor Freight? I've seen good things about the Harbor Freight aluminum racing jack in the past (at http://www.harborfreight.com/cpi/ctaf/disp...emnumber=91039) and was wondering if that's still good. Anything else I need? I seem to remember reading something somewhere a long time ago about a hockey puck... Loren - I didn't see any jacks in the reviews, but feel to move this if you like
  6. Have been on a business trip all week, so haven't had a chance to try to reproduce the problem when not in gear. Normal routine is as follows: back car out of driveway (relatively flat area), stop, put in drive, and head down the driveway. About 100 feet from garage to bottom of driveway. Stop, push clicker, and proceed after gate opens. Stop on other side of gate at street to make sure no cars coming, then proceed. Bottom of driveway at street has enough slope that nose will scrape ever so slightly unless going very slow. The slip occurs when stopping right before the gate, or when stopping right after the gate before hitting the street. It doesn't feel like any kind of traction problem, and like I said, nothing similar happens on my Boxster, or any other car I've driven down the driveway. I think PSM is standard on the 997, so the car has that. Not sure if that would affect braking. Tires are original Michelin Pilot Sport
  7. Wouldn't warped rotors be apparent other times as well? I haven't tried it in neutral. Good idea. :thumbup: I'll give that a try
  8. Car parked inside our garage - dry. Only happens slowly downhill in our driveway, haven't experienced it anywhere else. So don't think it's oil, etc on wheels, pads, rotors.
  9. about 5,000 miles - my wife's daily driver. New in March '05, been doing it since new
  10. Not as far as I can tell. It it has, it's been an extremely short blink only
  11. Heading downhill in my driveway, maybe 5 MPH, and have to stop at the bottom of the driveway for my gate to open. Press on the brakes (not real hard, since going slow), the pedal presses, it feels like the brakes are slipping, then the brakes grab again. It's never been felt in any other car, and my '01 Boxster (manual) does not do it. At first I thought it might be the transmission, but I've had it happen in tip manual mode in both 1 and 2, and in the automatic mode. I haven't noticed any dash lights coming on when it happens to help pinpoint what's going on. It's not always repeatable, maybe one out of 5 or 10 times. Driveway surface is dry asphalt, so water / wet is not the issue.
  12. sticker says 2006, but Scouser's VIN decoder says it's a 2005!?
  13. Here's one that has my dealer perplexed so far... The brakes on my wife's 997 tip will sometimes slip and then grab at the bottom of our driveway at speeds under about 5 MPH. It's steep, but not extremely steep. Speed doesn't seem to matter. Happens in either first or second gear. The service manager is speculating it might be ABS related, and may come over some time to try to reproduce the problem. It happens on a dry asphalt surface. No skidding or anything, just unnerving to my wife. Has anyone else seen anything like this? Are there any known issues with ABS programming on the 997? The car is totally stock, and it's happened to me as well as to my wife.
  14. I saw Foreign Intrigue's ad in the recent Excellence for a brand new Boxster Owner's Maintenance Manual. Here's the link to their web site: http://www.foreignintrigue.com/specials_html/986/index.htm Does anyone know anything about this manual? Is Bruce Whittier really a "well known individual, (that has excelled in the German Automotive Manual writing business for years)"? Any chance it has more information than found here?
  15. $3K was for parts and labor, but that was with 10% PCA discount as well. My memory is really getting bad. I thought there were several items listed, but the only part on the invoice is: 997-844-900-70, Retrofit Kit - Nav, list price $2,690 The retrofit kit includes the fiber optic cables, GPS receiver, etc. The existing screen inside the car was used. The service manager said there is a problem with the earliest build cars, and more parts were needed. I was lucky in that I didn't have one of the first cars.
  16. I printed that off for her right after I had the nav installed (great feature of the web site by the way), but still, if you spend $3K, it should at least come with instructions :eek:
  17. My wife's 997 did not come with nav, but she wanted it. Dealer ordered the parts and fully installed with 10% PCA discount came to a few dollars over $3K. Works great, except it didn't come with a manual and the dealer is still trying to track one down. I can post the parts list installed if you need it.
  18. My car (2001 2.7) used to very occasionally make a horrible metal on metal grinding noise. Dealer could not reproduce. Finally, right before warranty ended (February 2005), they replaced the starter. Haven't heard it since. But now, every so often, I get a cross between a sucking/squeal and your elephant sound. It doesn't sound nearly as bad as before. So I guess it's the starter, and not the engine smashing itself apart.
  19. If you're looking for metal, try http://www.boothedesign.com/centercaps.html - kind of pricy, though
  20. I'm pretty sure they're plastic (I'm on a business trip right now, so can't check). I think Boothe (sp?) makes something similar in metal
  21. What about these - the one on the right? This is the new 987/997 style center caps with the large colored crest. My wife's new 997 came with these, and I'm thinking about replacing my smaller Porsche colored crests (shown on the left) with these. I think they look better. Plus, they look like they'll hold up better, because they don't have the cheap piece of plastic covering the crest.
  22. I asked this question on the Boxster side, and didn't get any responses, so I thought I'd try the 996 guys... I installed the Litronic headlight upgrade with the control unit on my Boxster, and the control unit works fine (lights rotate up on high beam). As received, the headlights were pointing up at the tops of trees on low beam. My dealer adjusted them the other day, and now they seem to be OK. I've read about the ball and socket gimbal coming loose on many when they are shipped (as mine were). If the dealer adjusted them and they rotate properly, is it safe to assume the ball and sockets are all properly connected? Is there any other way to tell if things have come loose inside? Does anyone have pictures showing what the inside of the lights look like when the ball and socket are loose, and what they should look like? Thanks
  23. I installed the Litronic headlight upgrade with the control unit, and the control unit works fine (lights rotate up on high beam). As received, the headlights were pointing up at the tops of trees on low beam. My dealer adjusted them the other day, and now they seem to be OK. I've read about the ball and socket gimbal coming loose on many when they are shipped (as mine were). If the dealer adjusted them and they rotate properly, is it safe to assume the ball and sockets are all properly connected? Is there any other way to tell if things have come loose inside? Does anyone have pictures showing what the inside of the lights look like when the ball and socket are loose, and what they should look like? Thanks
  24. Loren, That did the trick. One good yank loosened the visor enough to pull it the rest of the way out. Thanks On my Boxster, I tried several things to remove the airbag stickers: 3M Adhesive Remover, Lacquer thinner, and denatured alcohol. The alcohol works the best, and that's the only thing I used this time
  25. Went to tech session at a local dealer last fall, and with car up on rack they point out several oil leaks. I take to my regular dealer and have the RMS and ISS seals done around 31K miles. Oil filler tube replaced at the same time. Valve cover leak fixed also. All leaks visible when looking at engine, but no oil spots on the ground. Around 33K miles in February, took car in right before 4 year warranty up, and dealer pronounced no oil leaks. (It's a 2001 Boxster) Went to tech session at same local dealer a few weeks ago, and the mechanic points out the same oil leak they found on the right side last fall. Take back to my regular dealer this morning to have the oil leak taken care of. In both cases, tech session mechanic says engine is leaking oil by freeze plug Just got off the phone with my service manager and he says the bank 1-3 (i.e., right side) head gasket is leaking oil to the outside. No oil / water mixing, or anything like that. Just external oil leak. No big deal, just replace the head gasket. No head machining, no break-in once fixed, Porsche has replacement head gaskets. Anyone else have this kind of leak before. I've heard lots about RMS, ISS, valve cover and oil filler tube leaks, but nobody complains about head gaskets leaking oil visible on the outside. What gives? Any suggestions? This dealer has taken VERY good care of me under warranty, and Porsche is paying for this repair. Also, no temperature problems or check engine lights have come on. Anything in particular I should be worried about (other than more oil leaks in the future)?
