Rear parking assistant cleaning procedure?
You need to find someone to read the fault code(s). Where are you located?
The loudspeaker emits the following signals:
System readiness - 0.5 sec. continuous tone, 1200 Hz.
Fault signal - Continuous tone whenever just switched on, 600 Hz.
Obstacle detection - Signal tone with tone break.
Tone break is distancedependent. Continuous tone from distance of 30 cm, 1200 Hz.
