About the painted plug covering the tow hook hole on the 987 Boxster (possibly all are the same). How do you remove the plug safely without damaging the paint?
Scary: paint+screwdriver+scratch?!
I was hoping for a gentler method?
Try a toothpick wrapped in paper towel. Should tip right out and then you can grab it.
If you need a replacement, we stock 'em.
