I'm trying to do the PSS9 installation and I'm having problems with the front. How do I disconect the driveshaft so I can get the old strut out?
While the car is still on the ground - remove the large axle nut.
Lift the car and after you have the lower ball joint out move the wheel carrier away from the axle. Support the axle with some wire.
Do your strut change then reverse the process - you will need to torque the FWD axle nut to 340 ft/lbs (460 Nm).
