I am trying to remove the map tray under the steering column. It seems to be help in place with what I imagine would be screws but they are flat, almost like plugs but I can't get them out. Any suggestions?
Doc1.doc
There are 2 plastic "rivets" that have a pin in the middle. This pin expands the the rivet. Hard to see that there is a pin in the middle. You need to push the pin out.
:jump:
Thank you
Do you know the Porsche p/n for these plastic fasteners.
