996 Dash Kit
I want to remove the Factory Becker Radio and install a double-din monitor in the Upper Dash.
I need to relocate the HVAC controls to the upper-position in the lower dash (currently occupied by the CD-holder-gizmo). Is there a wiring kit needed, or does the factory wiring reach? (i've seen other people mount it down there)
Does anyone have a list of all the optional (factory or 3rd party) dash components for the dash? I've seen a few posts when searching, but most of the parts seemed to be for the accessory pockets.
-Joe
MY2002 996 C2 CAB w/Bose
Edited by DiscobayJoe
-Joe
What are you going to do with the CD holder gizmo? I have a cd player and a cassette holder gizmo.
J Greer
J Greer
I'll PM you when I finally yank it (it'll probably be in Late January/Early Feb after I have a door switch problem fixed under Warranty)
  • 4 weeks later...
Discobay Joe
Did you have any luck with this?
When I tried to do it last night, I found that the HVAC control was too big for the top slot in the lower console (where the CD holder was).
Looking for a solution to this before I take my Dremel to the whole thing...
Discobay Joe
Yea, it only fits in the lower slot in the lower console. It's a tight fit, but it goes in. Remove the batwing. To move it down you need the following (pricing from SunsetImports.com)
996 552 339 00 01C $3.55 (Trim Ring)
Optionally, I added this:
996 552 253 01 01C $25.48 (Cubby to mount in the upper slot of the lower console, above HVAC)
If you are going to install a double-din head unit, you might also want the main dash frame without the bar across the middle. Will Prevent Extra Dremel Work:
552 231 12 01C $30.07 (Main Dash Frame, double-Din opening)
To remove the frame above you have to remove the vents. I just yanked on mine and they popped out, but I realized this wasn't the way to do it. You can insert a screwdriver thru the vents to push on the tab (There is a good description in the PCM2 DYI)
  • 4 weeks later...
