I went to look at a 2001 M6 cab at the local carmax lot. I've noticed that clutch did not engage till the very top of the pedal travel. That isn't normal, right?
When I started the car, there was a pretty loud tapa-ti-tap sound to the engine, which continued to be present until the engine warmed up. Sounded like chevy piston slap or the car was low on oil (it wasn't)
The car had over 60K miles and three owners. It was sensible priced at $38K, but I think you get what you pay for, right?
Edited by PeterK
Both are normal.
The clutch release may seem high compared to other cars - but the clutch is hydraulic so that is where it is.
The noise at startup is likely the hydraulic lifters. If the car hasn't been started for a few days this is normal. It should go away in the first 2-3 minutes.
Both are normal.
so both noises are normal and not indicative of any impeding problems?
