I did a search in this website and I found the instructions to re-teach the sunroof switch on my '01 996 coupe. Once the sunroof goes through the motions of opening and closing, it operates like normal. The problem is that after five minutes, the switch needs to be retaught again. I went to my local Porsche dealer late last night before they closed and they downloaded the same instructions from their computer. They said that the sunroof might need to be lubed and perhaps even removed and all tracks cleaned etc. Is it possible do lube myself with silicon spray? Is there anything else that can be done?
