996 Goes Flat
What is expensive? I have no idea what the price is in the U.K. On the continent it cost about Euro 140.00.
Yes it can be checked with a PIWIS tester, menu - DME - actual values. A fault code is not always necessarily, a disturbing in the airflow results in a problem. This is not really a DIY job. Replace the air mass meter if necessarily.
Regards
Regards
Is there anything else I should check? or is it only likely to be the air mass meter?
Regards
  • 7 months later...
Sly74, hi, i have exactly the same problem on my 98 C2.....It just start the other day after i had disconnected the battery to sort out my malfunctioning alarm......Its like hitting a switch, you get to 5000 and it still revs, sounds the same but doesn't actually pull like it used to...has disconnecting the alarm done something???
Yep, it was the MAF....i tried re-booting by removing the earth but it made no difference, cleaned out the throttle body again did nothing, so then went for a drive to get i warm. I stopped and unplugged the connection and the engine died. It started fine, idled real smooth and pulled like it never has before...all the way to 7!!
I called my local bosch parts place "Tytherleigh Vehicle Electrics" and was quoted £172 plus VAT (17.5% for the Americans) which i didn't think was too bad......Rang the Porsche Dealer and they wanted £339 plus, so guess where im going on Monday!!!!
This forum has been very helpful in sorting out this problem so thats guys
This forum has been very helpful in sorting out this problem so thanks guys
  • 5 weeks later...
HI All
Just to let everyone know I have had my car serviced and replaced the MAF sensor. The car goes like it should. Amazing that one sensor
could make such a difference.
Thanks to all of you that helped with this problem. A big thanks to Joe & Phil @ HP Motorsport, Hainault. These guys serviced the car for me, and made
my 911 run like a 911 should.
