Hi all,
I am just about ready to tackle my front brakes. I am going to replace the front rotors and pads with factory Porsche parts. They look straight forward. Are there any tips or obstacles to look for? I see toolpants that you were going to film a brake job for DVD. See if you came to Canada you could have done a top adjustment and brake DVD at the same time.
thanks
Marco
I would not be able to find Canada with all that snow.
We did film a brake pad change and brake fluid replacement in sunny California. I have not looked at the video yet to see if it is good enough for a DVD.
It is easy to change the pads. To remove the caliper to remove the rotor you need an allen bit on a ratchet wrench for the 2 allen bolts. Think it is 10mm.
The retaining pin for the pads is a tight fit. I use a punch to drive out the pin.
Once again thanks for the photos. Now I heard you shouldn't reuse the caliper bolts. What are your thoughts?
You know what Porsche says. Porsche also says to not reuse the springs and clips. My dealer does not stock these parts - special order. Use common sense and if you see something that is not 100% good then replace it.
  • 6 months later...
Try several import car parts places. We have a local one that sells aftermarket brake pads for $45. We put a front set in a few months ago on a base Boxster and the owner says they are fine. They are not fancy race pads for $200 or have the Porsche logo but fine for normal street driving. They also have the holes for the wear sensors.
I think they are sold under different names in the aftermarket. The name on the back of the pad is RMSA, which I think is Remsa of America owned by TRW. http://www.remsaofamerica.com/default.htm
The picture shows the box and 2 of the pads on the left. The single pad on the right is the old pad. The name on the box is Qualitee, but I have seen the same pads in a box with a different name.
