I've got a buddy that broke his timing chain on his low mileage MY99. No mechanical overruns or other abuse.
What do we know about the likely causes of this?
Is the timing chain and supporting hardware a known weakness of MY99?
TIA!
that is VERY strange. i wouldn't think it would break unless something else in the engine siezed first. which chain was it, IMS side or oil pump side? my first guess would be maybe some debris in the oil pump locked up the pump and the resulting stress snapped the chain.
My guess would be an IMS bearing failure that took the chain with - or a piece (of something like bearing) broke off an jammed the chain.
You won't really know until you open the engine.
