Upgrade to 3-Spoke streering wheel.
I have tried to remove the Airbag from my old 4-Spoke steeringwheel.
It seems to fit a size-4 umbraco and a T25 Torx even better, but perhaps a T27 is the perfect fit.
Can anyone tell me exactly what tool will fit the 2 4-Spoke steeringwheel screws ?
Kind regards
Morten
  • 3 months later...
It's true that they are in very tight from the factory. But also keep in mind that loosening of a bolt that is facing away from you requires you to turn in the opposite direction. Make sure you're not turning the screwdriver the wrong way.
I couldnt manage to find that tool in the two tool-stores I went to, so now I ordered a screwdriver T30 from a online store :) It seems the screw i VERY hard :)
Thanks again... :renntech:
Good Day ... I am looking to upgrade my Boxster steering to 3-spoke, check from the Design911 cost about 1,+++
Big Question --> Would it fit my 1999 Boxster ???
Appreciate any feedback ... cheer ;)
Guess NOT MUCH :help: HERE .... quite :( Disappointed ...
Have you tried asking the folks that make that particular steering wheel?
Most folks upgrade to the Porsche 3 spoke wheel for the airbag and safety.
