Does anyone know how to remove the alumalook blank plates to either side of the airbag on the Sport Steering Wheel?
Is there any special trick needed to remove them?
I looked through the parts cataloge and there is nothing
for steering wheel parts. I would guess that once the air
bag is removed, then you undo the steering wheel nut
and the whole wheel cones off as one unit. Is there
a wheel that you like that you want to replace with your
existing one?
Paul
Yes, I bought the optional Thicker Sport Wheel but it came with tip switches. I need info on how to remove those and reinstall mine. I removed on screw but something else is holding it in :-(
existing one?
Paul
I had a tip switch replaced. Some how, it
broke and would wobble on the wheel. I had
it repaired under warranty. Because it was done under warranty,
they would not give me the broken switch. I think
the tip switche just pops out but I am not sure. You
might want to call the parts dealer and ask them.
Paul
Paul
dont know if you figured this out yet, but i remember just lifting on them and they pull off fairly easily. of course with the airbag off.
i am not sure if they come off as easily with the airbag on.
