Hello
I wondered if anyone out there would have a disc that contains the software needed to run the opal nav disks on a PCM1 16bit nav computer?
I am trying to avoid paying the ridiculous stealership prices for the nav disk that i will only use to update my nav software!!!!
Any help mch appreciated
Duncan
Hello
Duncan
I've sent you a personal message. Dave.
Hello
Duncan
Hi I have the same problem ! Any help where I can get this update would be appreciated ! Stian.
Hello
Duncan
I've sent you a message. Dave.
Hello
Duncan
I am in the same situation. any chance of sending me a message ;) Thanks D
I would also be very interested in any help, if that is not a problem... :)
TIA!
Nikos.
Come on guys, I dont have a production line here!! Have you already purchased the new maps??? If not, i got mine from www.navicd24.de and these guys will send you the 'software update' that you MAY require on proviso you send it back. I say MAY, as apparently when i spoke to them not ALL PCM1 will need the update, only the earlier ones. If you havent purchased it yet, maybe give these guys a call? If you have, i may be able to help you. Remember though, copy the CD because if you put the 'Porsche' maps back in the software will revert back and therefore you wont be able to use the new ones again (if you need the update?). Thats how i come to have the sofware..........
Thanks for all your trouble and the information. B)
I already have the maps but will contact the guys you mention an see what they tell me.
Nikos.
