I found a few drips of oil on the garage floor today, so I started poking around. It appears that there's a tube that's leaking oil, and it appears that it has been leaking for quite some time.
Can you tell me what this is? It's apparently spewing a good amount of oil, as a large part of the undercarriage is covered in oil/dirt muck.
Pretty hard to tell from the pictures where the oil is coming from. I recently had mine in for service and they had to replace the oil fill tube. It apparently had been damaged or just aged to failure.
Will
i actually want to know what that tube is in the second picture. you can see that there's a coating of oil at the top of the inlet/outlet of the tube...
